John Deere 4310 does not go forward or reverse
   / John Deere 4310 does not go forward or reverse #11
Fault code 21. Machine does not drive. Caused by "Controller sees forward input but does not receive a back feed from forward pressure transducer". Test forward proportional solenoid and forward pressure transducer.
Thanks for the info.
My reverser switch is a hand switch up by the steering wheel, this module was replaced last year.
There is also a electrical/mechanical switch on the clutch telling it the clutch is out. I just replaced that on Saturday.
It seemed to work after I replaced that switch but only for about 2 hours. That is when I got the error code.
Where can I get a John Deere repair manual at a reasonable price?
thanks again, JIm
   / John Deere 4310 does not go forward or reverse #13
TM1985 is the paper manual and around $150. TM1985CD is the CD and it was about $75.
I have gone to my local dealer and they have printed parts of manuals for me. They will also loan out their paper manuals too at times.
   / John Deere 4310 does not go forward or reverse #14
I know this is an old thread - was the problem resolved?
I have a 4310 ehydro, and it ran fine but wouldn't move. I got code "short long long short" - supposed to be the MFWD sensor. I replaced that, didn't fix it. Turns out, it was the hydraulic oil rubber manifold collapsing. I just happened to glance at that as I was walking around the tractor at some point. The collapse was caused by me not fully cleaning the screen filter under the mid-tractor. I had cleaned it, I thought pretty well, at the last service. But when I took it back out, it had a coating of what looked like light grey paint. I used parts cleaner and a medium stiff brush to carefully clean it. Took quite a while but I cleaned until I get a lot of sunlight through it. Put it back, refilled oil, tractor works great.
   / John Deere 4310 does not go forward or reverse #15
Since the thread has been revived, I'm going to move it over to the John Deere section. It might be helpful to someone over there.
   / John Deere 4310 does not go forward or reverse #16
I'm going to take it as a one long and three short as there is no other code that comes close. That code is fault code 9 which is "simultaneous command from forward and reverse". Reset action is that "error status will reset when both pedal commands return to zero"
I have no experience with this but am thinking that you have something wrong with one pedal.
Let me redo this as I'm giving you info for a ehydro trany.
I'm having the same issues with my 3520 but have no codes.I was looking at the Hydraulic schematic and its shows a Change Flow Filter .I guess you can clean this out?I am going to try this next .The only problem is I am out of town for two weeks.So I wont have results till then.
EPPS Powerhouse Pressure Washer (A55973)
EPPS Powerhouse...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
HUSQVARNA CHAINSAW & BLOWER (A58374)
HUSQVARNA CHAINSAW...
2019 PETERBUILT 579  DAYCAB (A58214)
2019 PETERBUILT...
2019 Ford Escape SUV (A56859)
2019 Ford Escape...
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
