John Deere 4310 does not go forward or reverse
   / John Deere 4310 does not go forward or reverse #11
Fault code 21. Machine does not drive. Caused by "Controller sees forward input but does not receive a back feed from forward pressure transducer". Test forward proportional solenoid and forward pressure transducer.
Thanks for the info.
My reverser switch is a hand switch up by the steering wheel, this module was replaced last year.
There is also a electrical/mechanical switch on the clutch telling it the clutch is out. I just replaced that on Saturday.
It seemed to work after I replaced that switch but only for about 2 hours. That is when I got the error code.
Where can I get a John Deere repair manual at a reasonable price?
thanks again, JIm
   / John Deere 4310 does not go forward or reverse #13
TM1985 is the paper manual and around $150. TM1985CD is the CD and it was about $75.
I have gone to my local dealer and they have printed parts of manuals for me. They will also loan out their paper manuals too at times.
   / John Deere 4310 does not go forward or reverse #14
I know this is an old thread - was the problem resolved?
I have a 4310 ehydro, and it ran fine but wouldn't move. I got code "short long long short" - supposed to be the MFWD sensor. I replaced that, didn't fix it. Turns out, it was the hydraulic oil rubber manifold collapsing. I just happened to glance at that as I was walking around the tractor at some point. The collapse was caused by me not fully cleaning the screen filter under the mid-tractor. I had cleaned it, I thought pretty well, at the last service. But when I took it back out, it had a coating of what looked like light grey paint. I used parts cleaner and a medium stiff brush to carefully clean it. Took quite a while but I cleaned until I get a lot of sunlight through it. Put it back, refilled oil, tractor works great.
   / John Deere 4310 does not go forward or reverse #15
Since the thread has been revived, I'm going to move it over to the John Deere section. It might be helpful to someone over there.
   / John Deere 4310 does not go forward or reverse #16
I'm going to take it as a one long and three short as there is no other code that comes close. That code is fault code 9 which is "simultaneous command from forward and reverse". Reset action is that "error status will reset when both pedal commands return to zero"
I have no experience with this but am thinking that you have something wrong with one pedal.
Let me redo this as I'm giving you info for a ehydro trany.
I'm having the same issues with my 3520 but have no codes.I was looking at the Hydraulic schematic and its shows a Change Flow Filter .I guess you can clean this out?I am going to try this next .The only problem is I am out of town for two weeks.So I wont have results till then.
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
CATERPILLAR 627K SCRAPER (A52707)
CATERPILLAR 627K...
John Deere 1025R (A53317)
John Deere 1025R...
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52709)
(INOP) 2019 KUBOTA...
Bucket (A55973)
Bucket (A55973)
