John Deere 430 Overheats
/ John Deere 430 Overheats
I'm too sore to type right now. Just had my whole body tattooed green! Man, I love John Deere.
The tattoo was cheaper than a new grill.
/ John Deere 430 Overheats #23
You know that while the deck was off, you should of clean the bottom of the deck (the usual buildup, inspect the blades, sharpen and balanced if needed, grease the spindles, wheels, front wheel uprights, check the gearbox oil) while you wait for the oil to drain from the oil pan. Crawl underneath the tractor and remove the cover and grease the dive shaft u-joints. That is what I do on mine before mowing (My season: Beginning of May - end of NOV), mid season is end of July, and end of season before switching over for winter duty. That is usually 2-3 hours depending on the deck buildup.
I have a bad back and bad knees. So maybe it's time to sell off the equipment and pay to have it done for you.
You are absolutely right about looking the deck over. I checked everything recently when I had to take the deck off to find a part I dropped. If I had known about the oil plug problem, I would have changed the oil the same day.
From now on, I plan to get this thing in good shape in November, when it's cool. I didn't have any choice about the timing of replacing the alternator belt, but there are other jobs that can be moved.
I don't get buildup on my deck. Maybe it's because the grass here is so pathetic. In my area, you can't have a real lawn unless you irrigate constantly. The people who built my house put in a very fancy irrigation system that only waters the shrubs next to the house, which don't actually need water. I shut the system down for good. I have bahia grass, which is arguably inferior to painting your soil green.
I plan to keep grinding and cutting on the deck to make it easier to remove. Initially, I was reluctant to take an angle grinder to a machine people respected so much, but that feeling has passed. I can see more than one thing that can be modified to make the deck function somewhat less badly.
It's bad to get old and have back problems, but the reality is that this deck is not safe for anyone to remove at any age. It's a 325-pound object that requires you to bend over and pull on it while it resists you as much as it can because of design flaws. There is no way to characterize that as safe; it could screw up a disk in a teenager's back. I should start using my other tractor to pull it out.
/ John Deere 430 Overheats #25
Your profile says you are located in Florida.
This doesn't sound like Florida to me.
What's the scoop?
/ John Deere 430 Overheats #26
Well dang... some anger management may be in order here... wowwww.
If you hate the design so much, why dont you just get rid of it and buy something else.
The JD430 is a very small tractor, any tractor in its class is never going to be easy to work on, it is what it is.
But to come in here and flat out pee on everything and everybody, you`re only peeing in the wind.
People come in here to help one an other, but you`re just burning your bridge at this point.
:hissyfit::banghead::cryingeyesout::smiley_aafz::thumbdown:
I've started looking, but it sounds like I may be trading one badly engineered tractor for another, no matter what I get. Every time I start looking at a Kubota model I like, I find people talking about a major problem due to bad engineering.
I don't get this at all. I criticized a product and a company, and you say I'm peeing on people? Where is the connection?
What bridge are you talking about? Do I have to withhold criticism of John Deere in order to get advice here?
Seems to me that anyone who gets mad at me for being honest about this tractor needs anger management. You can say anything you want about my tractors or any other products I've bought, and it doesn't make me mad at all. I have a Dell computer, a Ford SUV, a Dodge pickup, and guns made by Colt, Smith & Wesson, Marlin, and Savage. I have a Taylor guitar. Go ahead and insult them. I don't care.
Why should I defend John Deere? I'm not John Deere's mom.
Am I supposed to be emotionally invested in a tractor company? Is that a good thing for an adult?
/ John Deere 430 Overheats #29
Which part doesn't sound like Florida?
The bold text. It sounds like somewhere in the desert southwest.
Sprinkler systems are very common in Florida.
Bahia is all over northern Florida.
/ John Deere 430 Overheats #31
I did not know that.
Sometimes knowing the general area of a fellow TBN'er saves some time and confusion.
At the risk of being referred for therapy, let me point out that the tire valve stems on the 430 are on the inboard side of the rim. Yes, you have to position the tractor exactly right, apply the parking brake, get on your knees in the dirt, and reach behind the tire to inflate it. God help you if the tire is flat.
I am assuming that the authorized John Deere mechanics who maintained this tractor didn't put the rims on backward, of course.
/ John Deere 430 Overheats #33
Rims are reversible to extend the rear wheel base width.
From 45" to 51.5"
Which way are yours set?
Do you have the Operator's Manual OM-M75883
Do you think you have the original type (turf) tires installed or are they the bar type (option) or other (grip)
/ John Deere 430 Overheats #34
Someone probably did that so they could mount wheel weights. You can swap them around to get the stems on the outside. Put the one on the right on the left side, and the one on the left on the right side.
/ John Deere 430 Overheats #35
That applies to the completely solid wheel weight and not one that has a cutout for the air valve which would also need an extension added on to keep it easy for airing the tires
JOST FIFTH WHEEL PLATE (A64276)
JOST FIFTH WHEEL...
JLG TELESCOPIC FORKLIFT (A64279)
JLG TELESCOPIC...
2018 Holbart 210 MVP Mig Welder (A64194)
2018 Holbart 210...
2007 Yamaha Rhino 4x4 Side by Side Gas Cart (A64194)
2007 Yamaha Rhino...
2019 KOMATSU D65PXI-18 CRAWLER DOZER (A65053)
2019 KOMATSU...
BUCK STOVE FIREPLACE INSERT (A64276)
BUCK STOVE...
