John Deere 420U
/ John Deere 420U #1
1946JD
John Deere B 1946
I'm getting ready to put some new seals on my john deere 420U on the clutch rod that goes throught the tranny on both side, but my question is if I pull the clutch pedal and shaft out to replace the seals will anything inside the tranny fall inside it and not be able to re aline it so it works again so I'm kinda needing some help on this one :confused::confused:
/ John Deere 420U #2
There is most likely a fork on the shaft that pushed the throwout bearing forward against the clutch fingers. Get a shop manual or see if a parts manual is available on line. It will show you what's inside the bell housing. I think the seals you are talking about are really bushings.
Pallet of Miscellaneous Duplex Polyester Webbing Slings (A56858)
Pallet of...
2020 ASV RT65 (A60462)
more info coming soon! (A61569)
more info coming...
2016 INTERNATIONAL 4300  4X2 24FT BOX TRUCK (A59911)
2016 INTERNATIONAL...
2007 Montone AD24465448 30ft. Tri-Axle End Dump Trailer (A61573)
2007 Montone...
H&H 100 GALLON ALLY WAY SPRAYER (A63291)
H&H 100 GALLON...
