John Deere 4120 Rear PTO stops spinning under load
   / John Deere 4120 Rear PTO stops spinning under load #1
Jercrew
Coweta, ok
John Deere/4102
I have a 2005 John Deere 4120 ehydro 600 hours.
When I use an implement (tiller or brush hog), the implant stops spinning under load. Once I lift the implement from the ground it starts spinning again. I have the correct RPM running, engine never bogs down. I don't use this tractor often, and have had it for 10 years, never used to be like this.
Tranmission fluid looks very clean, going to replace the fluid,filter and clean the inline filter. Not sure this will help. Need ideas of what could be the cause.
   / John Deere 4120 Rear PTO stops spinning under load #2
From what you describe it seems like tour pto clutch pack is slipping, but with only 600 hr it shouldn't be from wear, I am thinking maybe something like debris in an oil passage is preventing pressurized oil that engages and keeps the clutch engaged from getting there.
1268 (A50490)
1268 (A50490)
J & M 30' Head Cart (A50514)
J & M 30' Head...
2018 John Deere 470G Hydraulic Excavator (A50322)
2018 John Deere...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50774)
ALL TITLED ITEMS...
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2020 JOHN DEERE 3032E TRACTOR LOADER BACKHOE (A51243)
2020 JOHN DEERE...
