John Deere 4115
/ John Deere 4115 #1
chevy
Platinum Member
East Central, Indiana
Kioti CK3510SE HST, John Deere X739
I was out looking at some 2320 tractors today & came across a very low hour 4115 with a new 200CX loader. I asked the salesman if the 62D deck would fit on it. He told me no & I did not look at it any further. After I got home I was on the John Deere site & found they show the 62D deck will fit the 4115. Now I wish I had looked at it closer.
I have not been able to find any specs on the 4115.
How much different is the 4115 from the 2520?
/ John Deere 4115 #2
Here are some specs on the 4115. Nice tractor, I’ve been looking for one myself.
4115
Engine
Horsepower 24 (26 kW)
Rated Engine Speed 2,650
Torque 47.5 ft. lb.
Type 3 cylinder diesel
Displacement 73.22 cu. in. (1.2 L)
Cooling System Water Pump
Air Cleaner Dry-type with safety element and air restrictor indicator
Fuel System:
Type Direct injection, auto-bleed
Capacity 5.81 U.S. gal (22.0 L)
Drivetrain:
Transmission Hydrostatic
Final Drive Spur gear
Brakes Wet disk
Differential Lock Standart
4-Wheel Drive Standard
Hydraulic System:
Type Open center
Working Pressure 2,420 psi
Pump Dual gear
Lift Capacity 1,150 lb. (522 kg)
PTO
Type Independent
Clutch Multidisk, wet
Dimensions:
Length 108 in
Width 50.9 in
Wheelbase 64.6 in
Height 81 in
/ John Deere 4115 #3
Some have indicated on this site that the Hydraulics are stronger on the 4115.
/ John Deere 4115 #4
The 4115 and the 2520 should be matched very close.
The 4115 should take the 60" MMM or the 72" MMM, the 62D is a lighter duty deck compared to these.
/ John Deere 4115 #5
Is it just me, but I seem to observe that the 2520 has a higher CG than the 4115? The 4115 always looks lower to the ground to my eyes.:rolleyes:
/ John Deere 4115 #6
Dont see how that is possible. Having a 4100 (which had the same hydrolics as the 4110 & 4115), the 2520 is noticably stronger in FEL and 3pt in my observations
/ John Deere 4115
I got more information on the 4115. The hydraulic capacity of the pump for the loader & 3pt is about the same as the 2520. The capacity of the steering pump is about half of the 2520.
The tractor is a 2005 model with 1 hour on the meter. That is right 1 hour. It has never been sold & has a full factory warranty. It has set outside all of that time. It is rusty & the paint is very faded. The dealer is very proud of it because they are asking 16,300.00 with a 200CX loader.
/ John Deere 4115 #8
The price certainly is a good indication of why it is still sitting around. I believe you can pick up a new 2520 w/ 200cx for around 15.5k.
/ John Deere 4115 #9
Yeah, i think that price is too high too. It has been sitting outside and it has rust and scorched paint. I also think you can get a used 2520 with more hours for less than that.
/ John Deere 4115 #10
I should add the difference between the loaders is significant. The older 410 loader didnt provide as much lift height and capability as the 200cx's do.
The 3 pt and FEL ability is more than whats stated in the spec books. the 3pt will lift 1,300 lbs all day long (probably much more - I just dont have enough weight around to show or prove that)
FEL capacity in the spec is under stated as well.....how much? I can only speak with experience - 1000lb loads to max height on a regular basis for me...
But I would rather have others concure this as well....
/ John Deere 4115 #11
Chevy, if you are really still thinking that 4115,, try to get the dealer to lower that price significantly, $4-$5k?
/ John Deere 4115
I gave up on that dealer. It took them over a week to get back with me on a price for a 2320.
I decided on a 2320, 200CX & 62D deck from the dealer I have been buying from. I paid a little more, but the service I get there is worth it.
/ John Deere 4115 #13
Definitely sounds like you made a good choice based on the appropriate info.
Unused 2022 Hustler Lift Max LE110 SS Bale Forks and Frame Tractor Loader Attachment (A66734)
Unused 2022...
2017 Crane Carrier Co. T/A New Way 31ASL Side Loader Garbage Truck (A66736)
2017 Crane Carrier...
2006 Mercury 115ELPTO 115hp Outboard Boat Motor. (A66738)
2006 Mercury...
2023 JCB 3TS8T Teleskid High Flow Compact Track Loader Skid Steer w/ 7 Ton Gooseneck Trailer (A66734)
2023 JCB 3TS8T...
2013 Ford Fusion Sedan (A66738)
2013 Ford Fusion...
John Deere 2840 Tractor (A64047)
John Deere 2840...
