John deere 410C pump
   / John deere 410C pump #11
It's been since '87 since I was a JD dealer service manager and I have no utility tractor service manual but I think you're correct that rad & oil cooler need to be removed to access hyd pump
thanks, thats what I thought. Also I am sure it would be easier if the loader was raised but as I have no way of securing it is it possible to get the pump out with the loader down?
   / John deere 410C pump #13
A safe way to secure loader in the up position is to cut some sections of angle iron the correct length of exposed rod and place angle iron as "STOPS" held in place with a couple of hose clamps per cylinder
thanks for that tip, what are your thoughts on the oil cooler? the shop that is rebuilding my pump said it was okay to have a radiator shop clean it well, but all information I have read says it has to be replaced?
   / John deere 410C pump #15
I've had oil coolers cleaned/repaired by rad repair shop on ag tractors way back when I was a JD dealer service manager.
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
2016 Ram 5500 Enclosed Service Truck (A52377)
2016 Ram 5500...
2008 KALMER 4X2 SPOTTER TRUCK (A51247)
2008 KALMER 4X2...
UNUSED WOLVERINE LHR-51-23W 1R RIPPER (A54757)
UNUSED WOLVERINE...
