Backhoe John Deere 410B Hydraulic problem
/ John Deere 410B Hydraulic problem #1
JLazyA
John Deere 410B
I have a John deere 410b hoe with a hydraulic problem. It bareley moves when cold, as it warms up it moves faster. Anything hydraulic, steering, lifting, or hoe. We have changed the screen in the transmission, checked the line to the pump, and rebuilt the pump. And it is still the same. I think it is the priority valve but not sure what to check next.
/ John Deere 410B Hydraulic problem #2
First thing I would do is check trans pump psi & flow. PSI should be around 165-175 and flow 5 gpm. Usually it's the other way around. Works good when oil is cold and quits when oil gets warmer.
/ John Deere 410B Hydraulic problem #3
How do you check the PSI and flow??
Wooden
Where can I buy a gauge to start checking where the pressure isn't going???
Doyle Conveyer with Honda Engine (A63688)
Doyle Conveyer...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2023  FREIGHTLINER M2 22FT NON CDL BOX TRUCK (A59905)
2023 FREIGHTLINER...
2351 (A64281)
2351 (A64281)
POWELL / COLE 6R RIPPER (A63291)
POWELL / COLE 6R...
2020 Ford Explorer AWD SUV (A61574)
2020 Ford Explorer...
