John Deere 410B drive problem
/ John Deere 410B drive problem #1
ML33567
Florida
John Deere 410B
Hi guys. I have an 84 JD 410B. The problem I am having is that it wants to pull forward in forward and neutral and there is no reverse. I have found some bad linkage that controls the flow to the convertor on the control valve to the reverser. I replaced the broken parts and still have the same problem. When I have the floor boards out and can see the drive shaft it will drive in forward or neutral and will stop turning when I go into reverse but there is no power to go into reverse and turn the wheels. It will turn the wheels in forward or neutral. I pulled the control valve off and the gasket was in good shape and there was no visible scarring in either of the spool valves but I didnt remove them from the housing. I am leaning toward there being some sort of problem in the reverser but dont want to go into that if someone here knows something else I should check first. I do have ALL the books on this tractor. Any ideas? Thanks
/ John Deere 410B drive problem #2
Since you have the books, I ASSUME Tech Manual, see if it has pressure tests for the reverse.
I am guessing leaking reverse lines or clutch.
Thank you for your response. I found the problem. The forward clutch pack in the reverser has failed and it drives in forward whether in neutral or forward. It stops driving when I go to reverse because the reverse is working fine.
Well I was wrong. I found the problem in the brake pedal control valve. The middle pedal was hanging up and had something to do with the reverse. I freed up the pedal so it would go to the top of its travel and now have forward and reverse. Heck of a lot easier than rebuilding the reverser and cheaper too. I have been using it for a week now and it works great.
2250' of 5" Tile (A66408)
2250' of 5" Tile...
2004 Ford F-550 Flatbed Truck, VIN # 1FDAW56P24ED63182 (A65563)
2004 Ford F-550...
2017 Caterpillar DP70N1 15,500lb. Straight Mast Diesel Forklift (A64194)
2017 Caterpillar...
New 2x27 Ratchet Strap (A65579)
New 2x27 Ratchet...
Lonestar Panel (4) 24ft. Free Standing Panels (A65640)
Lonestar Panel (4)...
WILDKAT 78 ROCK GRAPPLE (A61572)
WILDKAT 78 ROCK...
