John Deere 4105
/ John Deere 4105 #21
I guess I should have bought NEW vs USED . $40.00 , I can live with that . Its a great tractor , so if thats all thats wrong with it I'll be happy !! 20 hrs so far !! :D
It is still under warranty correct? That is the whole point.
/ John Deere 4105 #22
The tractor has 20 hrs on it, or you've put 20 hrs on it since you got it? We are confused on the warranty issue. I'm impressed with your attitude.
/ John Deere 4105 #24
:( no warrenty left :(
If the service bulletin was dated before the warranty lapsed, you could probably insist the dealer or Deere covers it. I do think the Dealer should have, just for good customer relations.
However, 40 bucks isn't going to break the bank...goochy just needs to determine how much effort he wants to put into getting his money back.
/ John Deere 4105 #25
I am curious as this should have been addressed by the prior owner, but $40 bucks to fix it and Goochy can continue with his projects seems the easy way to go imo.
/ John Deere 4105 #26
Just curious why the service bulletin wouldn't cover non warranty units? I'd think any dealer worth his salt would be happy to make it right.
Matt:confused:
/ John Deere 4105 #27
Warranty only covers a certain number of hours and a fixed period of time. If a machine has 25 hours on it, but is 5 years old, it is out of warranty. Suppose a customer comes in at this time and says he has had a problem "since new". The manufacturer would not be willing to cover this failure. The dealer should not have to eat it. The owner has a responsibility to report problems in a timely manner. You would be surprised how often we hear similar stories.
/ John Deere 4105 #28
Is it leaking around the dipstick or the fill cap? Keep in mind that hyd oil expands when it gets hot.
I found this service bulletin.
I see the 3x20 series on that. I wonder if I should get the parts even though I'm not seeing hydro leaking? I'm still under warranty.
Rob
/ John Deere 4105 #29
Rob
Yes, I would like to see how your dealer handles this.
/ John Deere 4105
If I had bought tractor new , it would be fixed . but I got it USED , so ............. I am just happy he lowerd the price . Most dealers wanted $50-$60 . I had 3 different dealers tell me " Service Notices ONLY help dealers fix the problem quick " Its a guide , of what might be the cure to fix it . 3 dealers said NO to JD fixing it on a 2008 model
/ John Deere 4105 #31
I think what's going on here might be the 'you didn't buy it here' attitude. I think if your dealer gave you a discount than you should be happy. I'll bet if you bought the tractor new and this just showed up after all these years you find the dealer you bought it from having a different attitude.
I blew a shaft on a tractor that was out of warranty and my dealer made good on it with an improved shaft which means JD knew about it, just like your leak. The difference was that I bought the tractor new from him.
Rob
/ John Deere 4105 #32
Goochy,
It is possible that this is the reason the tractor was traded in to start with. Your showing up armed with the proper information to repair the problem may have been a suprize to the dealer. Years ago I bought a Deere 4020 at a firesale price because the mechanic had missed an inline filter to the hydraulic pump.
I would put the retrofit vent kit on it and call it good. That gets you back to operating the new tractor and having fun.
/ John Deere 4105
I'm just going to fix it and move on . Now IF it does NOT fix it , dealer WILL fix it !!!!! It was bought NEW there , sold to me there , and he said it NEVER had this problem . BUT the owner never used bucket much !
/ John Deere 4105 #34
I believe that and knowing Deere it very likely will fix it.
Rob
/ John Deere 4105 #36
Good deal, that puts you back in business so to speak.
/ John Deere 4105
THANKS for ALL the HELP !!!!!!!!!!!!!!!!! :thumbsup:
PLEASE READ (A63117)
Industrias America 435 (A64119)
Industrias America...
Kubota V3600-E3-EG60 Diesel Engine - 3.6L - Tier 4i - Irrigation Pump Takeout (A63689)
Kubota...
2020 John Deere R4044 Sprayer (A63111)
2020 John Deere...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
208315 (A58376)
208315 (A58376)
