John Deere 4100 wont start
   / John Deere 4100 wont start #1
Tubecat
Hi all, looking for some advice to troubleshoot. I have a 2000 4100 series compact 20HP tractor. I turn the key and the starter won't engage. The dash lights come on for a few seconds, sometimes it makes a burping noise and then the lights go out.
When the tractor is in neutral, sitting on the seat... in the past if this happened I would move the low/high lever back and forth and it would start. I also had a time where the seat button failed.
When you sit on the seat you can hear an electrical "click" under the dash...so I assume the seat switch is fine.
I have disconnected the switch to the transmission and put a jumper wire to see if that helps but does not make any difference.
I have put a test light to the starter and I have power from the battery but the other terminal has no power and assume it should when I turn the key?
What can I do to test/look for?
Is there a starter solenoid before the starter that might be bad? could it be the ignition switch itself?
Thanks for any advice
   / John Deere 4100 wont start #2
Let me sayIi don't know the details of your specific tractor so what I say applies generally to most starter systems.
If all the safety interlocks are functioning as they should when you turn the key your solenoid should close the contacts that connect the battery to the starter. So make sure all the interlocks are working as they should. The easy way to do this is to see if you have battery voltage to the small wire going to the solenoid when the key is switched "ON". If you do then the interlocks are working properly. Next check the ground connection on the battery. This are often forgotten but if your solenoid isn't grounded, there will be no current through the solenoid to close the starter circuit. If you use a set of jumpers and put the battery positive on the small solenoid wire and touch the battery negative to a good ground, your solenoid should click in and if the starter is good and grounded properly, the engine should turn over. (BE CAREFUL TO MAKE SURE THE TRACTOR IS NOT IN GEAR. You could have a closed circuit on the tranny interlock and if the tractor is in gear it could move).
If the solenoid clicks in and the engine does not turn over the starter is either bad or the contacts in the solenoid are burned or fouled. Put the positive of the jumper on the starter power connection and ground the negative and if the starter turns the engine over the solenoid contacts are bad.
   / John Deere 4100 wont start #3
I have a PDF of the technical manual of your tractor, if wanted shoot me your email and it's on the way. It will show you how to troubleshoot
your cranking system
Joe
Joe
Thanks folks....Awesome. My email is tubecat@hotmail.com. I tested again the seat switch and the transmission switch with a voltmeter and they seem ok. Per above I also ran a jumper directly to the small starter solenoid wire with the key on and the starter engaged but wouldn't start. I also verified power to the ignition switch, then with key on, 12 volts coming out of 2 terminals, when key in starting position 12 volts then also come out of the other 2 terminals... I am stumped.... thanks
Thanks.. tried a few of the above with no success.
   / John Deere 4100 wont start #6
Check all the cables and terminals on the battery.
   / John Deere 4100 wont start #7
I now have a copy of the WSM thanks tojoecdeere.
Can you describe in more detail: the starter engaged but would not start.
Was the engine cranking over?
This test would verify the starter condition but you would have had no glow plugs.
Also whatever type of engine stop solenoid is used, there might have been no fuel.
I will keep reading the WSM and will look for more info from you.
Is the transmission a Gear drive or something else?
I have marked the starter relay location in this next image.
Could you try having a finger on the relay and then turn the key to start. If the contacts close when you turn key I think you would feel it.
Dave M7040
   / John Deere 4100 wont start #8
I am lookng at the seat switch in the wiring diagram. I don't know how you are testing its three positions. Defeat, operator ON and operator OFF.
Did you know there was a defeat position? Typically used when needing to run something off the pto and you cannot stay in the seat to run say a log splitter.
The WSM is 595 pages of very good info. Your tractor is a complicated one and will be tricky to solve your problems without a methodical approach.
Please remove the ground point on the engine or frame end of the ground cable. Post a picture with the cable off.
Dave M7040
Thanks. The starter would only engage if I jumped it directly to the battery.... but then the starter could only turn over and the engine wouldn't start. so yes no glow plugs probably.... This is a hydrostatic transmission. This diagram helps. I will put my finger on the starter relay and see if I can feel it click.
   / John Deere 4100 wont start #10
More info from WSM
The safety systems are more involved on this tractor with each sensor sending a signal to a Control Module which then decides if the starter can engage.
Dave M7040
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2011 Ford F-250 4x4 Pickup Truck (A50323)
2011 Ford F-250...
2007 STERLING LT9500 SERIES MIXER TRUCK (A50854)
2007 STERLING...
2014 KENWORTH T800 SLEEPER CAB (A50854)
2014 KENWORTH T800...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2011 MACK GU713 DAYCAB (INOPERABLE) (A50854)
2011 MACK GU713...
