John Deere 4100 wont start
   / John Deere 4100 wont start
Ok, I will try some of this tomorrow. I took of a pic of the ground wire off but cant post it. I'll reconnect and try the above steps. thanks for your help.
   / John Deere 4100 wont start #12
How to test Key switch which is rarely a problem
Dave M7040
   / John Deere 4100 wont start #13
The logic module is a critical part in the starting and running of your tractor.
As the description states, it operates as IF somethings happen (seat switch, pto switch hi low switch etc) THEN the logic module sends power to the starter relay, the fuel relay the Glow Plug relay.
I appreciate how difficult going through these procedures to find what is wrong unless you do it for a living or have unique training.
If you want to go through the steps I will do my best to help you.
Usually it is something simple and stupid that is at fault and when found you will give yourself a good kick.
The control module is almost $500 on ebay.com so you don't want to start changing it until your are very very certain it is the problem
John Deere Control Box For 4:), 41, 411, and 4115 M87913 | eBay
As I look at the inputs to the control module I suggest you double check what you are doing.
For example, the hi low range selector has to be in neutral which is unusual in my experience. Have that in either Hi or Low and nothing works.
Dave M7040
   / John Deere 4100 wont start #14
Looking for some advice on my 1999 John Deere 4100 HST. When key is in the on position everything is fine, lights work etc. when I turn they key further to start the engine, it may turn over a few times but the fusible link on the starter blows immediately. Battery connections and grounds to frame are all good. I've looked for bare wires everywhere and can't find anything. Checked seat safety switch, PTO switch etc all good. Any help would be greatly appreciated. Snowing and blowing here and I need to get to work. Thanks!
   / John Deere 4100 wont start #15
I am not a forum expert but suggest starting a new thread would get you more help. If you do start a new thread PM me so I dont miss it.
What are you replacing the blown fusible link with?
I have a 4100 WSM from another member.
Do you have a wiring diagram in your owner's manual which you could post? I need to be certain your wiring diagram and the one in the WSM I have are the same.
To blow the fusible link means a serious current draw. You need to eliminate a number of circuits by removing relays and fuses to narrow down your search
Although it will likely not allow your tractor to start, eliminating the Glow plug circuit by disconnecting the GP relay is a good starting point. If the Fusible link does not blow as before, you will know where to start looking.
Dave M7040
Dave,
Thanks very much for taking the time to help me on this. I apologize for lack of response as have been out of town. I haven't had a chance to work on this in over a month but it is still sitting and won't start. With the weather here in Buffalo it won't be until March until I can continue to work on this. thanks again I really appreciate your time and will let you know how I make out.
John Deere 9450 Combine (A50514)
John Deere 9450...
2017 NISSAN NV200 VAN (A51406)
2017 NISSAN NV200...
Flat Deck Trailer (A50322)
Flat Deck Trailer...
TMA (A49461)
TMA (A49461)
UNUSED FUTURE EXCAVATOR COMPACTION WHEEL (A51244)
UNUSED FUTURE...
2008 INTERNATIONAL DURASTAR 4300M7 SBA 4X2 DUMP TR (A51243)
2008 INTERNATIONAL...
