John Deere 4100 electrical/no start issue
   / John Deere 4100 electrical/no start issue #1
Rdmmo
Canandaigua NY
John Deere 4100
Looking for some advice on my 1999 John Deere 4100 HST. When key is in the on position everything is fine, lights work etc. when I turn they key further to start the engine, it may turn over a few times but the fusible link on the starter blows immediately. Battery connections and grounds to frame are all good. I've looked for bare wires everywhere and can't find anything. Checked seat safety switch, PTO switch etc all good. Any help would be greatly appreciated. Snowing and blowing here and I need to get to work. Thanks!
   / John Deere 4100 electrical/no start issue #2
Maybe begin by removing wires and cables one at a time and tracing the voltages to find out where the problem lays.
   / John Deere 4100 electrical/no start issue #3
Sounds like the starter...especially if it is the only thing on the fuseible link
   / John Deere 4100 electrical/no start issue #4
Ditto. I suggest to attempt to check amp draw on starter while engaging starter.
   / John Deere 4100 electrical/no start issue #5
Internal short on the starter.
   / John Deere 4100 electrical/no start issue #6
Everyone done picked my diagnosis: internal short in starter.
Hmmm. Just not sure it's in the starter because it will turn over and seems to work well before fusible link pops
   / John Deere 4100 electrical/no start issue #8
When the fuse pops use a volt meter to check resistance to ground. Dead short would read zero
Bad connection could also cause excessive amp draw which would trip the fuse.
   / John Deere 4100 electrical/no start issue #9
Put a clamp on amp meter on the power cable and see what it's drawing. Either you have a starter motor going bad, some kind of short, maybe a bad connection or the engine is binding and causing a heavy load. Could be a binding alternator or water pump.
Starter is good. Removed and had it load tested and everything checked
out fine
2021 CATERPILLAR 289D3 SKID STEER (A51242)
2021 CATERPILLAR...
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
Kohler 30 Generator (LOCAL TOWNSHIP) (A50774)
Kohler 30...
2008 Ford F-750 Crew Cab Pro Patch TCM-425-135 Asphalt Patcher Truck (A51692)
2008 Ford F-750...
JLG 800A MANLIFT TELESCOPIC/SCISSOR BOOM (A51242)
JLG 800A MANLIFT...
2019 CATERPILLAR 308CR EXCAVATOR (A51242)
2019 CATERPILLAR...
