Oil & Fuel John Deere 4100 Does NOT start
/ John Deere 4100 Does NOT start #1
GREEN4100
Texas
John Deere 4100
Hello forum...! I know there has been plenty of discussion around John Deere 4100 tractors not starting. I'm in the same boat but can't get a specific answer from the other topics. My 4100 had been starting fine until late. When I first start the tractor it turns on fine, but seems to be running on fuel that was unused from the previous time I ran it. It then dies after 10 seconds or so. After that I would crank it a few times until finally it would start up again. Today the tractor has not started at all. It ran for 10 seconds as mention above, but now will not start. I have check all the lines and up to the fuel pump and fuel is flowing. The fuel filter is new. I also took off the fuel solenoid and when I turn the key the solenoid clicks and the metal pin does pull in. So does anyone have any other suggestions... i.e. bad fuel pump, injectors bad. In other words if my problem sounds like something you have fixed before please provide your solution.
This is a cool forum, hope to get my problem resolved with your help! :cool:
Thanks
OS
/ John Deere 4100 Does NOT start #2
Thanks
OS
Did you try loosening or removing the fuel cap?
I just want to update everyone, although I didn't get much help from this forum. My problem ended up being the fuel lift transfer pump. The lever spring on the pump would not compress which would not allow fuel into the injector pump. Once replaced tractor started up immediately.
Part used: pump -- AM876410; gasket -- M805703
/ John Deere 4100 Does NOT start #4
I'm glad you got it running. Thanks for the update. Trying to diagnose tractor problems while gazing into a "monitor screen" is difficult at BEST. Jim(former JD dealer service manager)
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
1997 Fontaine 48Ft Flatbed Trailer (A64194)
1997 Fontaine 48Ft...
Kubota V3600-T Turbo Diesel Industrial Engine  63kW (84 HP)  2016 Model  Pump Takeout (A63689)
Kubota V3600-T...
2012 UTILITY VS2RA 53X102 REFRIGERATED TRAILER (A59914)
2012 UTILITY VS2RA...
(1) 40 Yard Roll Off Dumpster and (1) 30 Yard Roll Off Dumpster (A65579)
(1) 40 Yard Roll...
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
