john deere 410 backhoe barely moves forward but moves in reverse ok
   / john deere 410 backhoe barely moves forward but moves in reverse ok #31
Does it only have 100 psi in reverse also?
Yes I checked both of them and they are around 100 psi. The reverse was sort of hard to check because it moves in reverse so I had to stop after it started moving in about 10 feet but it only got up to 100 psi in that short time. I guess I could block up the back wheels and try it again if you think it would make a difference in the answer that you will give my.
   / john deere 410 backhoe barely moves forward but moves in reverse ok #33
How did the screen look? maybe that is a clue to what else may have been going on. Just a WAG.
The screen looked good there was just alittle gray sludge at the one end but the rest was clean
   / john deere 410 backhoe barely moves forward but moves in reverse ok #35
I think you need to try to raise trans pump pressure to about 160 psi IE try to determine why pressure is low.
How do I raise the Trans pump pressure or what should I look for to determine why the pressure is low. Thanks for all your help so far
   / john deere 410 backhoe barely moves forward but moves in reverse ok #37
I'd be concerned with the "gray sludge" at the end of the screen... as it may be a clue to what is plugging up something else in the system.
The screen, I'd expect, to be there to trap particulates such as steel chips from factory machining or gear wear. Sludge indicates, to me, that there may be problem elsewhere. Just my thought though..
I think the sludge was from the drum off the forward clutch drum because the c clip that was broken and the washers where sliding up the shaft and woar the drum down a bit so I think the sludge was from that. I had the drum fixed and new parts put in.
Any other ideas why the pressure mite be low or what to look at to figure this not.
Thanks
   / john deere 410 backhoe barely moves forward but moves in reverse ok #40
The trans pump is just a gear pump that bolts to the reverse brake housing. Check your service manual there may be a way to adjust relief valve on the reverser clutch control valve that bolts onto the side of the reverser. Without my manual I can't remember for sure what the relief in the reverser control does exactly.
When you had the reverser out, did you replace all sealing rings in both clutch packs and the orings on all of the tubes inside?
You can air test this unit just like an auto transmission. When you add air to the proper tube, you can hear the clutch packs engage.
JOHN DEERE 8345RT TWIN TRACK ROW CROP TRACTOR (A57192)
JOHN DEERE 8345RT...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
Swict 72" Quick Attach Bucket (A56469)
Swict 72" Quick...
2003 FORD F350 XLT SUPER DUTY CREW CAB TRUCK (A57192)
2003 FORD F350 XLT...
1992 AM General M998 HMMWV 4x4 Humvee Truck (A55852)
1992 AM General...
CRATOS SHERPA 100 ECO ELECTRIC STAND ON SKID STEER (A57192)
CRATOS SHERPA 100...
