John Deere 401C Hydro trouble
   / John Deere 401C Hydro trouble #91
Or is it a three-way valve I need?
   / John Deere 401C Hydro trouble #92
Ok, I plugged the weeping hole(and leaving the valve in the PCV, couldn't justify removing it yet) and I'm still in my woes of no FEL operation. I'm thinking of adding a two way 12V valve to split the two functions, FEL & RS. Or maybe a hydraulic one....
I'm in the winter season and playing around with this hydraulic system is starting to get long & cold!
By plugging the "weeping hole" (which I think you mean the hole to let oil from the spring side of the internal valve go to sump), BUT NOT removing the internal valve, you caused the internal valve to "hydraulic" lock. With out the weep hole, the valve can't move, even if there is enough pressure in the system.
Unlike an AG PCV, you only have to remove the rear plug to access/remove the internal valve. Remove it and try that. If you still have problems, that only leaves the Rockshaft. Leaking valve or cylinder.
   / John Deere 401C Hydro trouble #93
That makes sense to me, I plan on removing the innards. Good catch!
   / John Deere 401C Hydro trouble #94
Removed the internal valve and still the same woes. I checked for flow of oil inside the tranny but I don't see any, I must be blind or could be low on oil. Will check it again when time permits. Might have to get a 3way valve for the winter.
   / John Deere 401C Hydro trouble #95
I think this narrows it down to the rockshaft/3pt hitch.
   / John Deere 401C Hydro trouble #96
I hope this a somewhat easy pull out assembly to work on a table. It will have to wait for Spring.
Thx again and a safe Merry Xmas!
   / John Deere 401C Hydro trouble #97
Merry Christmas! I have never had one (rockshaft) apart, but I bet TX Jim has seen a lot of them worked on.
   / John Deere 401C Hydro trouble #98
Yes I've witnessed several JD utility 20-40 series tractor rockshaft housings removed & resealed The seals aren't near as difficult to R&R especially when comparing to other JD tractor valves that require adjustment with a micrometer.
I hope everyone had a Merry CHRISTmas & will have a happier New Year.
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
Craftsman T1800 42in. Riding Mower (A49346)
Craftsman T1800...
2014 John Deere 6125M Utility Tractor (A50657)
2014 John Deere...
2013 MACK PINNACLE CHU613 DAY CAB (A50854)
2013 MACK PINNACLE...
