John deere 3720 front axle seal.
/ John deere 3720 front axle seal. #1
Catenary Kid
Concord
JD 350 crawler loader w/backhoe/JD 3720 w/loader/Massey Ferguson 235D
How difficult/expensive is it to replace a seal in the front axle of a 3720? Does it require a bunch of special tools, shims, what? I found a nice little puddle of oil on the floor under the right front wheel of my new-to-me 2009, 3720. Any advise would be appreciated...
/ John deere 3720 front axle seal. #2
Sorry no one replied to this. The axle seal is pretty easy to change if you haven't found out already.
You might take the wheel off though, and look on the bottom of the knuckle or pivot as there is a plug there. I replaced a neighbors that had popped out on his 3720.
TT, Many thanks - I'll check that out...
FYI: I was in a local JD dealership last week and spoke with them about it. I was told that it's generally about $600.00 for both front wheels so maybe $300.00 for the one. Given my history with repairs of this sort, I'm going to let them do it...
/ John deere 3720 front axle seal. #4
Doing some re search on a totally different machine..but have you opened up your check/fill plug? How much pressure is behind it? Alot of these front axles arnt vented.
You may want to open the plug and clean the area. If you still have a leak then it's a bad seal. If its pressure related you may want to add a vent.
UNUSED FUTURE SGB20-20" HYD STUMP GRAB BUCKET (A60432)
UNUSED FUTURE...
Adams Tender / Magnolia Trailer (A61307)
Adams Tender /...
2019 KUBOTA KX033-4 EXCAVATOR (A60429)
2019 KUBOTA...
3-Stage Forklift Mast with Forks (A59228)
3-Stage Forklift...
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
2015 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2015 FORD F-250 XL...
