John Deere 3255 Loader Plumbing
   / John Deere 3255 Loader Plumbing #1
BCMac
Horsefly, BC
John Deere 3255, Massey Ferguson 35, Massey Ferguson 1080, Ford 8N, John Deere D110
Hey gang - I have a 1992 3255 that I am looking to put a loader on. I have found a 260 with frame mounts for the 2950 which I beleive are the same with the supports to the rear axle. It comes with the loader, bucket, grabble and joystick.
Next step is I need to figure out what else I am going to need to get it all hooked up. Then figure out how to hook it all up. I believe that I would still need the valve for the 3255. Is that correct? Is there anything else that I am overlooking?
Also if anyone can point me to any posts, articles or Youtube videos of the process, that would be super cool. My GoogleFu is failing me.
   / John Deere 3255 Loader Plumbing #3
Might help you finding the "alike" supports by going to jd parts site.
Browse through there and see if you can match up the parts you have found with the parts that fit both the 2950 and the 3255.
   / John Deere 3255 Loader Plumbing #4
Ditto what beenthere stated about researching parts catalog #1814. IMHO hyd components for 2950 & 3255 should be identical including valve
   / John Deere 3255 Loader Plumbing #5
If anything like my JD 245 loader, the valve for the joystick, mounts inside a box on the right loader frame. Mine uses the bracket highlighted in yellow. To mount the box on the top of the loader frame. LMK if you need pictures from my JD 2030 with JD 245 loader.
Pressure hose to the valve will "TEE" into the line from the PCV (Pressure Control valve), coming out of, or to the rear of the PCV. The return to sump hose will connect to the transmission oil filter cover. It must have a "ported" filter cover/housing.
Thanks Jim that would be amazing if they do as the package has the valve for the 2950 as well. I think I actually saw another post of yours elsewhere that made me aware of all the compatible mounts. Thanks for sharing your wealth of knowledge.
From everything I have seen, the 3255 is the same. Hoses feed from the loader into that box and joystick out and up into the cab.
This is the first time I've actually had to fit a loader to a tractor and not just come with it and I am finding these Mannheim machines to be a challenge.
   / John Deere 3255 Loader Plumbing #9
You're very welcome. I don't have any personal experience with a 3255 but have experience with mounting FEL on 2950/2955's. Closed center hyd system's on most JD Mannheim built tractors are very similar. Does your 3255 have a ported hyd filter cover?
That I don't know yet. The tractor isn't where I am at right now, so I will have to check when it is.
If it doesn't are they difficult to come by? I just did a quick Google search that didn't bring up much of anything.
2015 FORD E-350 14 PASSENGER VAN (A52472)
2015 FORD E-350 14...
BESTWAY AG VSK50 LOT NUMBER 105 (A53084)
BESTWAY AG VSK50...
2017 FORD F150 REG CAB LONG BED 4X4 (A52577)
2017 FORD F150 REG...
2015 Ford Escape SUV (A50324)
2015 Ford Escape...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
2021 DEERE 333G LOT NUMBER 198 (A53084)
2021 DEERE 333G...
