John Deere 325 with Kawasaki …losing power momentari
   / John Deere 325 with Kawasaki …losing power momentari #1
topolgwc
Jd 325
Runs ok , occasionally starts spurtering, runs rough for 15-20 secs And corrects itself. Then it’s ok for many hours. Sounds electrical but where do I start?.
   / John Deere 325 with Kawasaki …losing power momentari #2
Welcome to TBN
Typically, electrical issues show up when things get hot, and they would not get better while on the go. I would suspect bad fuel, perhaps, water in the fuel tank or in the carb float bowl.
I would recommend draining the fuel tank and make sure that there is no water at the bottom of it. Also loosen the float bowl bolt and let some fuel out of it.
Richard
   / John Deere 325 with Kawasaki …losing power momentari #3
when it is sputtering try choking it some to see if runs. If yes then most likely fuel related. I had one where the float valve would occasionally stick causing similar symptoms.
2022 John Deere 1025R (A53317)
2022 John Deere...
202483 (A54757)
202483 (A54757)
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55851)
iDrive TDS-2010H...
2022 Schulte SMR-800 Multi Rake Landscape Windrower (A56435)
2022 Schulte...
2014 GMC Terrain SUV (A56859)
2014 GMC Terrain...
2015 INTERNATIONAL FLATBED (A58214)
2015 INTERNATIONAL...
