John Deere 325 with Kawasaki …losing power momentari
   / John Deere 325 with Kawasaki …losing power momentari #1
topolgwc
Jd 325
Runs ok , occasionally starts spurtering, runs rough for 15-20 secs And corrects itself. Then it’s ok for many hours. Sounds electrical but where do I start?.
   / John Deere 325 with Kawasaki …losing power momentari #2
Welcome to TBN
Typically, electrical issues show up when things get hot, and they would not get better while on the go. I would suspect bad fuel, perhaps, water in the fuel tank or in the carb float bowl.
I would recommend draining the fuel tank and make sure that there is no water at the bottom of it. Also loosen the float bowl bolt and let some fuel out of it.
Richard
   / John Deere 325 with Kawasaki …losing power momentari #3
when it is sputtering try choking it some to see if runs. If yes then most likely fuel related. I had one where the float valve would occasionally stick causing similar symptoms.
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A55973)
2015 Freightliner...
SKID STEER ATTACHMENT HAMMER (A58214)
SKID STEER...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2025 Starvox SV-480 23HP Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple... (A59225)
2025 Starvox...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
