John Deere 325 Lawn tractor deck wont engage
   / John Deere 325 Lawn tractor deck wont engage #1
bodine99
Stacy, MN
I have a John Deere 325 lawn tractor and this winter the snowblower would work on and off, When I switched it to the mower deck I get nothing when I pull the switch to engage the blades. I replaced the switch and still nothing, I checked the connection and the fuses on the side by the ignition and all seemed good. Is there another switch or fuse underneath that may have gone bad? I am not sure what to check next, all help will be greatly appreciated.
   / John Deere 325 Lawn tractor deck wont engage #2
Check the seat switch, I believe there is also a relay for the pto
   / John Deere 325 Lawn tractor deck wont engage #3
I had the same problem with my 325. I bypassed the seat switch with a piece of wire to verify it wasn't the switch. Next I bypassed the connection at the circuit board that holds the fuses. It turned out that I had to replace the whole circuit board. It was only 80 bucks and I installed it myself in like 5 minutes.
2023 Bintelli Beyond Golf Cart (A51573)
2023 Bintelli...
JOHN DEERE XUV835M LOT NUMBER 25 (A53084)
JOHN DEERE XUV835M...
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
(APPROX 60) DIAMOND TREAD DBL AXLE FENDER BACKS (A51247)
(APPROX 60)...
(10) Replacement Thumb Cylinders (A51573)
(10) Replacement...
2016 FORD F250 XL SUPER DUTY EXTENDED CAB TRUCK (A51247)
2016 FORD F250 XL...
