John Deere 325 Lawn tractor deck wont engage
   / John Deere 325 Lawn tractor deck wont engage #1
bodine99
Stacy, MN
I have a John Deere 325 lawn tractor and this winter the snowblower would work on and off, When I switched it to the mower deck I get nothing when I pull the switch to engage the blades. I replaced the switch and still nothing, I checked the connection and the fuses on the side by the ignition and all seemed good. Is there another switch or fuse underneath that may have gone bad? I am not sure what to check next, all help will be greatly appreciated.
   / John Deere 325 Lawn tractor deck wont engage #2
Check the seat switch, I believe there is also a relay for the pto
   / John Deere 325 Lawn tractor deck wont engage #3
I had the same problem with my 325. I bypassed the seat switch with a piece of wire to verify it wasn't the switch. Next I bypassed the connection at the circuit board that holds the fuses. It turned out that I had to replace the whole circuit board. It was only 80 bucks and I installed it myself in like 5 minutes.
2013 INTERNATIONAL PAYSTAR DAY CAB ROAD TRACTOR (A51406)
2013 INTERNATIONAL...
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
2025 New/Unused Wolverine Pallet Fork Frame with Forks (A51573)
2025 New/Unused...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
2018 JLG 3246ES 32ft Electric Scissor Lift (A51691)
2018 JLG 3246ES...
