John Deere 325 Lawn tractor deck wont engage
   / John Deere 325 Lawn tractor deck wont engage #1
bodine99
Stacy, MN
I have a John Deere 325 lawn tractor and this winter the snowblower would work on and off, When I switched it to the mower deck I get nothing when I pull the switch to engage the blades. I replaced the switch and still nothing, I checked the connection and the fuses on the side by the ignition and all seemed good. Is there another switch or fuse underneath that may have gone bad? I am not sure what to check next, all help will be greatly appreciated.
   / John Deere 325 Lawn tractor deck wont engage #2
Check the seat switch, I believe there is also a relay for the pto
   / John Deere 325 Lawn tractor deck wont engage #3
I had the same problem with my 325. I bypassed the seat switch with a piece of wire to verify it wasn't the switch. Next I bypassed the connection at the circuit board that holds the fuses. It turned out that I had to replace the whole circuit board. It was only 80 bucks and I installed it myself in like 5 minutes.
2015 Caterpillar 410L 4x4 Extendahoe Backhoe Loader (A51691)
2015 Caterpillar...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53472)
2019 Krause...
1991 Mack RW713 Day Cab Truck, VIN # 1M1AY10Y4MM005693 (A51572)
1991 Mack RW713...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2021 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A52377)
2021 Ford F-250 XL...
2022 Case IH Steiger 470HD AFS Connect RowTrac 4WD Tractor (A50657)
2022 Case IH...
