John Deere 3203 won't start
   / John Deere 3203 won't start #1
jc1960
Orting, wa
John Deere 3203
I have a 2006 John Deere 3203 that has been relatively free of issues but within the last week after being used the tractor sat for a few days and then would not start. Since it was the original battery I replaced it and found no difference. After looking I noticed the ignition fuse was blown so I replaced it and when I turned the key partway the instrument panel came on but when I tried to start there was a click / clunk and the fuse blew again. This repeated twice, any suggestions or has anyone else had this issue?
thanks
   / John Deere 3203 won't start #3
What's the location of the fuse that keeps blowing? Like F1 or what??
   / John Deere 3203 won't start #6
Ok that's the one I thought it might be. I'll do some looking into tomorrow on the schematics. I'll be in touch
I pulled the starter and if I turn clock ways it turns freely, if I turn counter clock ways it extends and turns.
   / John Deere 3203 won't start #8
Something similar happened to me recently. It was corrosion on the battery cable attached to the starter. I would just hear a click when turning the key.
   / John Deere 3203 won't start #9
When out does the starter respond when key is turned?
Will the flywheel turn?
I tried to see what would happen with the starter out and nothing happened, would I need to get it grounded to the frame? I took the starter in to the dealer and they tested it and said it was fine, I talked to the tech and he said it sounded like I might have a short in the system and said it could possibly be the ignition switch. For 45 bucks I bough a new one and if it quits pouring rain I will try and figure out how to get to it.
2014 FREIGHTLINER M2 DAY CAB (A51222)
2014 FREIGHTLINER...
John Deere 4520 Tractor (A50514)
John Deere 4520...
2015 KOMATSU PC170LC-10 EXCAVATOR (A50458)
2015 KOMATSU...
2018 Dodge Ram 3500 4x4 Utility Flatbed Truck - HEMI Gas, Gooseneck Hitch, Southern Truck (A51039)
2018 Dodge Ram...
John Deere 270 Wheeled Skid Steer (A50322)
John Deere 270...
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
