John Deere 318 Not Charging!
   / John Deere 318 Not Charging! #11
Just thought I'd give an update, and thanks for your input! I replaced the switch. I looked up the part numbers on JD, then Google for 'crosses'! (Yeah, I'm 'thrifty') Switch from JD- $19-, switch from local small engine guy- $12.99. That solved the 'wiggle-thing'! Pulled the two outside regulator leads and have 32VAC at medium idle. They call for 26-52VAC at high idle, so I'm in the range! re-plugged them, and pulled the center lead on the Reg, and got no DC output! Looks like the regulator!! Called JD for Reg price, $81-!!! Checked Google for a 'cross' that led me to EBay. and ordered an exact replacement for $31-!! More to follow! Thanks Again! ~Scotty
Glad to be of help. Keep us posted and let us know if the regulator fixes the problem.
   / John Deere 318 Not Charging! #12
Scotty,
There is a difference between cheap and thrifty:
A thrifty person saves a dollar here or there, so he can spend it on something else, like beer
A cheap person saves all his money and drinks his friends beer :D
Final update: Replaced the Rectifier/Regulator. Plugged in the Stator wires, and again 30-40 VAC! With the center lead disconnected I read no DC volts when tested to ground! I had 12vdc from the lead that plugs on to that center terminal, but knew I was just reading battery voltage! Thought I had a bad part! Plugged it in anyway, and viola!! Battery light goes out, and I've got 14VAC from the (connected) center terminal to ground!!! Guess I had to have a 'draw' on it, before it 'kicked in'!! Some things electrical, I just figure, "It's Magic" and move on! Looks like I'm good to go!!! Thanks again!! ~Scotty
   / John Deere 318 Not Charging! #14
Scotty: Congrats! See my first post to you question also.
regards
Wayne
   / John Deere 318 Not Charging! #15
Glad to hear your running again! It's alway good to hear when the problem has been solved.
2015 Polaris Sportsman 570 SP ATV (A50514)
2015 Polaris...
10' Feed Bunk (A50515)
Portable Fuel Tank (A50515)
Portable Fuel Tank...
2007 Polaris Ranger (A50514)
2007 Polaris...
1265 (A50490)
1265 (A50490)
2015 Eager Beaver 15HBB-PT T/A Flatbed Equipment Trailer (A50322)
2015 Eager Beaver...
