John Deere 3046R - From R1 to R14T tires?
   / John Deere 3046R - From R1 to R14T tires? #1
lee1sd
Vassar, MI
John Deere 4320
I recently purchased a 3046R that came with R1 Ag tires. Been using it in the yard doing some landscaping, and obviously tearing up the grass quite bad. I also plan to do a ton of work in the woods, and I'm worried about the R1 tires sidewall not standup up to the sharp cutoff brush stub, stumps, etc.
I've been researching the R14T and seem to be a good option that would cover all uses. Anyone with similar size tractor and experience? Should I make the switch? I know I can sell my R1's as they are basically brand new, but it's still going to be a decent size investment to make the switch -- especially having to get new wheels and tires for correct fit.
So far, the Goodyear R14T tires are most appealing from treat design, but aren't radials...which I'm slightly concerned about:
Galaxy does make a radial R14T, but the tread design doesn't look nearly as good to me:
Appreciate any advice from people with experience. Plan on making the switch, but don't want to waste time and money if not worth it.
   / John Deere 3046R - From R1 to R14T tires? #2
I don’t own any but have turfs on mine. I know the ones you are looking at are a good compromise but I’ve also heard they are still hard on the lawn but I’m sure much better than ags. My turfs will tear up the lawn if I’m not careful.
   / John Deere 3046R - From R1 to R14T tires? #3
I have the R14's on my little Kioti. I am well pleased with there performance on gravel and on the lawn.
They are actually on an R1 type carcass not an R4 carcass.
These are the 15-19.5's
2014 Ford F-550 Ext. Cab 4x4 Auto Crane 6406H 6,400 LB Crane Service Truck (A55788)
2014 Ford F-550...
John Deere 644G Wheel Loader (A47477)
John Deere 644G...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2008 Isuzu NPR-HD Landscape Dump Truck (A55788)
2008 Isuzu NPR-HD...
202477 (A54757)
202477 (A54757)
United 5' 3pt. Box Blade (A50775)
United 5' 3pt. Box...
