John deere 300
/ John deere 300 #1
JohnDeere300
Kewanee,IL United States
John Deere 300, John Deere 314, John Deere 112
I am gonna buy a John Deere 300 but it has a oil pan leak. So it needs a new oil pan gasket. How hard is that kind of a job.?
/ John deere 300 #2
Is it a garden tractor or utility sized tractor ? If it is the garden tractor you will have to remove the engine . That should have the K 341 Kohler , single cylinder 16 HP . Once it is out the pan gasket is simple . That engine is heavy .
/ John deere 300
Yes its the garden tractor. And thank you for your help. Will I have to disconnect the wiring harness too then?
/ John deere 300 #4
Yes but I think there are only a couple wires going to the engine itself . You will need to undo the driveshaft that goes back to the hydrostat trans . There is acoupler where driveshaft hooks to engine . Hope this helps .
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
9008SFL (A64556)
9008SFL (A64556)
2015 VANTAGE TRAILER 3 POD PNEUMATIC TRAILER (A63569)
2015 VANTAGE...
SELF-PRIMING CENTRIFUGAL PUMP (A65643)
SELF-PRIMING...
2015 IC Corporation PB105 School Bus (A61568)
2015 IC...
SDlanch SDLL580 (A64127)
SDlanch SDLL580...
