John Deere 2520 Tach problem
/ John Deere 2520 Tach problem #1
ecr64
Brighton, Colorado
John Deere 2520
Hi all,
I have a 2007 JD 2520 that has 420 hrs on it that has been working perfectly for my light duty work on my 2.5 acres. Recently I am having a problem with the tach and wanted to know if anyone has experienced a similar problem and hopefully can recommend a fix. Every now and then, the tach needle on the display goes all the way to the max hard stop and I hear a high pitch "squeal". Throttling back does not affect (or correct) the situation. If I turn off, and restart the problem goes away for a while and then comes back after some time. Any thoughts? I haven't looked under the instrument cluster yet to check if something is loose, but that's my next step.
Thanks!
-E
/ John Deere 2520 Tach problem #2
I would start with the loose connections. Don't forget to check the ground wires. A loose ground can cause strange readings on instruments.
/ John Deere 2520 Tach problem #3
Loud squeal of a rotating shaft/instrument sounds like a dry bearing to me if mechanical. If electronic, I'd go with the loose connection Dave mentioned. If you loose ground on electronic circuits, no telling what they will do. A sloppy fitting connection could be doing just that as the shield on the cable/connector is usually part of the ground circuit.....I suppose.
/ John Deere 2520 Tach problem #4
Some tachs run off the alternator (usually stamped with a ("W") check the connections there also.
2018 DODGE RAM 5500 FLAT BED TRUCK (A65643)
2018 DODGE RAM...
Front Tank Bracket (A64126)
Front Tank Bracket...
2001 INTERNATIONAL 4700 4X2 S/A UTILITY BODY TRUCK (A66091)
2001 INTERNATIONAL...
2014 CATERPILLAR 924K WHEEL LOADER (A65053)
2014 CATERPILLAR...
2012 Freightliner FLD120 Ambulance (A64556)
2012 Freightliner...
Hydraulic Breaker Excavator Attachment (A64553)
Hydraulic Breaker...
