john Deere 2320 noisy snowblower?
   / john Deere 2320 noisy snowblower? #21
The pillow block came from thebigbearingstore.com for less than $30. the cv joint is a reman out of a late 90's dodge colt $35 on fleabay. I did use the original drive shaft. cut the U joint off machined the cv joint and driveshaft yoke to slide into each other then welded it together..
The bearing fits perfectly over the driveshaft stub so no machining there. I made the mounting bracket and mounted it so it doesn't interfere with the mower deck so it doesn't need to be taken off in the summer.
If I did this attachment correctly it has the pics of my driveshaft.
http://www.tractorbynet.com/forums/john-deere-owning-operating/112188-2210-snowblower-vibration.html
   / john Deere 2320 noisy snowblower? #22
Would you consider selling a setup? I assume it would be the same as a 2210
Can't stand the vibration much longer on mine
Gary
   / john Deere 2320 noisy snowblower? #23
Converted mine over to a CV joint and it is now as it should have been built by John Deere. I would have expected better from them.
Thanks to Labrat's design it's a keeper again.
FORREST RIVER CHEROKEE CAMPER (A55745)
FORREST RIVER...
1994 Toyota 6000lbs 2 Stage Forklift (A53472)
1994 Toyota...
Quick Attach Bucket (A47477)
Quick Attach...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55302)
NEW HOLLAND 706 30...
INGERSOLL- RAND AIR COMPRESSOR (A56129)
INGERSOLL- RAND...
Decorative Horse Lamp (A55758)
Decorative Horse...
