john Deere 2320 noisy snowblower?
   / john Deere 2320 noisy snowblower? #21
The pillow block came from thebigbearingstore.com for less than $30. the cv joint is a reman out of a late 90's dodge colt $35 on fleabay. I did use the original drive shaft. cut the U joint off machined the cv joint and driveshaft yoke to slide into each other then welded it together..
The bearing fits perfectly over the driveshaft stub so no machining there. I made the mounting bracket and mounted it so it doesn't interfere with the mower deck so it doesn't need to be taken off in the summer.
If I did this attachment correctly it has the pics of my driveshaft.
http://www.tractorbynet.com/forums/john-deere-owning-operating/112188-2210-snowblower-vibration.html
   / john Deere 2320 noisy snowblower? #22
Would you consider selling a setup? I assume it would be the same as a 2210
Can't stand the vibration much longer on mine
Gary
   / john Deere 2320 noisy snowblower? #23
Converted mine over to a CV joint and it is now as it should have been built by John Deere. I would have expected better from them.
Thanks to Labrat's design it's a keeper again.
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A54607)
2014 HINO 338 26FT...
2007 Chevrolet C6500 Landscape Dump Truck (A55788)
2007 Chevrolet...
2018 CATERPILLAR 303.5E2 CR EXCAVATOR (A52705)
2018 CATERPILLAR...
UNUSED RETRACTABLE AIR HOSE REEL (A54757)
UNUSED RETRACTABLE...
New Idea 6254 Round Baler (A50775)
New Idea 6254...
