John Deere 2305 Neutral Position
/ John Deere 2305 Neutral Position #2
Got 250 hours on my 2305 and I have never seen this. When I take my foot off of either pedal, the tractor comes to a stop.
/ John Deere 2305 Neutral Position #3
On that style of hydro pedal, you rock the pedal to go forward and back. I think all the Deere's have two different pedals. One for forward and another for reverse.
Yes anything mechanical can break but with two pedals it is rare. Most of the posts for that in Deere forum involve debris preventing the pedal from returning to neutral. Do a search of past forums search there are not many current problems.
Here is a search using "deere pedal stuck" keywords.
TractorByNet.com - Search Results
/ John Deere 2305 Neutral Position #4
I managed to get my Deere 2305 (2010) stuck axle-deep in soft mud. Rocking back and forth, the transmission pedal stuck in forward position, so I cut the engine but then was trapped because nothing I did (lifting the forward pedal, pushing the reverse pedal, etc.) brought the pedal back to center, even though I could start the tractor with high-low gear lever in neutral position (so, I could choose between having the tractor in gear, or having the engine run). Next day (Monday) call to the dealer's best mechanic assured me nothing was likely broken on the inside of the transmission, and I probably just had some mud preventing the pedal return somewhere in the linkage. After considerable excavation and cleaning, I couldn't find the problem. Additional phone conversation with the mechanic told me how the linkage works: at the rear of the linkage is a stabilizer piston (a few inches long, about an inch diameter) that functions only to provide soft return of the pedals, kinda like the piston that holds up a car's hatchback. Epiphany. It turned out the piston was bent, and was stuck in the extended position. The strut proved ridiculously easy to remove (one cotter pin removed by hand, and the other attachment-point just slid outward off a pin. It looks like a perfectly sized and positioned stone (between rear wheel and stabilizer piston) must have mashed the outside of the piston. Tractor works fine without it, but I have a replacement on order (list price $216, ouch). Seems this is a rare event, maybe a first.
/ John Deere 2305 Neutral Position #5
Welcome to TBN:D
That "piston" is called a "dash pot", I had no idea it was that expensive!
/ John Deere 2305 Neutral Position #6
JD calls the part a "torsional dampener" part number AM115862 and was quoted both on Deereparts.com and by my local dealer at $169 for my 2210. I was having pedal sticking issues, too. Turns out one of the bearings in the linkage was all but siezed. Glad I didn't go for the dampener.
/ John Deere 2305 Neutral Position #7
In this thread http://www.tractorbynet.com/forums/kubota-owning-operating/137802-bx-neutral-return-position.html they are talking about the tractor continuing to move forward after lifting off the pedal. Had a guy say the same thing happens on his Massey GC. This happen on the 2305 at all?
Yep, it's been happening to my 2210, the pedal "sticks", the faster I'm going the worse it sticks. A light tap on the brake pedal pops it up. I talked to my dealer today and we discussed the linkage. I came home and checked everything over. When static (engine off) the pedal was behaving exactly as it does when driving. I removed the torsional damper (shock absorber thingy) and I had my wife move the pedals while I sprayed Panther Piss (WD-40) on all the bearings along the linkage. At the point that I sprayed the bearings on the last shaft before the transaxle the pedals suddenly loosened up and worked normally. Appears one of the bearings was nearly siezed?
I would like some feedback on how to lube those bearings without spraying everything with dust absorbant wd40?
Rhino 7ft Blade (A63688)
Rhino 7ft Blade...
2023 BOBCAT T66 R-SERIES SKID STEER (A64279)
2023 BOBCAT T66...
2022 EZ-GO ELITE...
2019 INTERNATIONAL LT625 T/A 6X4 SLEEPER TRUCK TRACTOR (A59912)
2019 INTERNATIONAL...
2020 MACK ANTHEM 6X4 T/A SLEEPER TRUCK TRACTOR (A59912)
2020 MACK ANTHEM...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
