John Deere 2030 Hyd issues
/ John Deere 2030 Hyd issues #1
tcpirate
Larrabee Wi
John Deere 2030
Hello, I have a John Deere 2030 8 speed no reverser and no hi-lo, pto lever is between the shifters it has a 146 loader which is currently off the tractor. Here is my problem, when the tractor gets up to operating temp the only way the three point will raise or power steering will work is if you rev the tractor way up. When the oil is cold it seems to work ok. I changed the oil and filtter and checked the screen. Also I looked through the oil fill for oil spraying with the three point all the way up, no oil spraying but there is a steady stream of oil comming down. Any help would be greatly appreicated. Thanks.
/ John Deere 2030 Hyd issues #2
:welcome: to TBN
Steady stream of oil viewed in hyd filler hole indicates that 3 pt control valve seals &/or rockshaft piston seal is leaking. I recommend replacing both while RS cover is off of tractor. You could also cap power steering feed line on RH of tractor to determine if PS is leaking internally or use laser thermometer to see if PS valve housing is hotter than rest of hyd's.
I have another diagnostic thought: Does tractor have SCV? If so loosen mounting bolts then remove return hose from RS housing. Crank engine and no oil should exit hose with control lever(s) in neutral.
Thanks for the info, I know it's been awhile lot of irons in the fire, we have all the seals/ orings replaced with the exception of the rockshaft piston seal. It appears that JD updated from the original, the plastic ring is now solid not split any suggestions on how to get it on the piston. Again thanks for your help.
/ John Deere 2030 Hyd issues #4
Warm plastic ring in warm water then slide ring onto piston.
/ John Deere 2030 Hyd issues #5
I will add that when sliding plastic ring over the piston, it will stretch some and make it difficult to slide piston in the cylinder without damaging the new seal. Try compressing it with a ring compressor or hose clamp. If using a hose clamp, use a piece of shim stock or even a piece of thin cardboard between seal and clamp to prevent damaging the seal. If you compress it for 10 minutes or so, it will slide in much easier. Put grease or oil on seal before sliding piston back in.
Everything is back together and the only problem we solved is the three point doesn't settle anymore, which needed to be fixed anyway. Still the same problem, when the tractor/oil is cold everything works fine but once it warms up the steering, three point and loader chatter/move slow. What about the lines for the pto that can fail is there any way to test them. Thanks, Tom.
/ John Deere 2030 Hyd issues #7
The internal lines for the PTO when they fail will cause an internal leak to sump for the line that fails. Either the PTO clutch line or PTO brake line. Temperature would not make a difference. Only way to test is see if symtoms change when PTO is engaged.
ON my 2030 the PTO clutch line failed (broke) causing a leak to sump and loss of other hydraulics. Disengaging the PTO and hydraulics returned to normal. Replacement lines are heavier than originals. I recommend replacing both if you split the tractor for any reason.
/ John Deere 2030 Hyd issues #8
1st test hyd pressure on test port under cover that gearshift levers protrude through after removing cover. Pressure should be 155 psi. Then to test hyd pto clutch & brake tubes remove trans shift cover and blow compressed air into tubes while listening for escaping air. How is loader controlled(scv or ind valve)? Cap line leading to power steering then operate with no PS and report back how hyd operate.
Loader has ind valve, capped PS and three point raises normal, no chatter, loader is currently off tractor.
/ John Deere 2030 Hyd issues #10
If 3 pt raises normal with PS supply capped then PS has one or more blown o-rings(parts key 4). O-ring can be renewed while valve body remains on tractor by removing steering wheel then remove big nut then screw shaft with control valves out of PS housing.
We are ready to reinstall the power steering unit, I took the whole assembly to our local JD dealer and had them go through it. Before removing the valve body the manual says to remove the drain plug on the right side of the clutch housing to drain the oil, which I did. There was a fair amount of sludge in the bottom of the housing, any ideas of where it came from. Also do we need to put oil back in the housing before putting it back together? Can't figure out how the oil gets in there. Thanks, Tom
/ John Deere 2030 Hyd issues #12
The sludge in that area is a normal occurrence. The oil flows very slowly through there and Deere says that the earlier HyGard had graphite in it that settled out of the oil in that area. You do not need to add any oil to that area. It is filled with return oil out of steering valve.
Well, it looks like it was the o rings in the power steering valve that were causing the problems. Thanks everyone for all your help.
2011 GMC SIERRA 2500HD (A67714)
2011 GMC SIERRA...
2014 Ford Transit Connect Handicap Van (A61573)
2014 Ford Transit...
2025 JMR Tree Boom Skid Steer Attachment (A66734)
2025 JMR Tree Boom...
213135 (A64276)
213135 (A64276)
PALLET OF HOSES (A68842)
PALLET OF HOSES...
1997 FONTAINE FLATBED (A67714)
1997 FONTAINE...
