John Deere 2013-2015, 5E series brake problem?
   / John Deere 2013-2015, 5E series brake problem? #51
My guess without access to a 5055E tech manual is by tightening/loosening cap screws(parts key 3) note that washers(parts key 5) are spring type.
That did it! Thanks. Much smoother now.
I had looked at JD parts before trying to figure it out but to no avail.
   / John Deere 2013-2015, 5E series brake problem? #52
Thanks for the update. You're welcome I'm glad I could help you,Jim
   / John Deere 2013-2015, 5E series brake problem? #53
This thread was reason enough for me NOT to buy a 5E series.
   / John Deere 2013-2015, 5E series brake problem? #54
Did you have to tighten or loosen to help it out?
Ronnie
   / John Deere 2013-2015, 5E series brake problem? #55
I have never had this problem on my '13 5083e. The brakes work fine. I am at almost 500 hours. It has been a good tractor so far...
   / John Deere 2013-2015, 5E series brake problem? #56
Ronnie
Loosen.
My setup was a little different actually, not sure if the parts schematic tx jim posted was from an open station or a international model, but my tractor had two bolts that applied pressure on the the spring disks. I loosened both about 1/5-1/4 of a turn and it made a dramatic difference. I could see how from the factory it would be easy to over tighten - not much leeway.
   / John Deere 2013-2015, 5E series brake problem? #57
When I posted parts photo I saw no differentiation between OS & cab model for 3 pt control lever. One needs to loosen screws to lower tension and tighten screws to increase tension on control lever.
   / John Deere 2013-2015, 5E series brake problem? #58
Edit...meant 5E 3cyl. 5083E is 4cyl and bigger/different tractor.
   / John Deere 2013-2015, 5E series brake problem? #59
I would just stay away from all the 5E's. In Canada anyway they are WAY overpriced for what they are. Green Diamond quoted me over 80k for a 5100E, very basic tractor, no powershift, very light duty, nothing fancy. While shopping around it looks like 80-90k will get a much heavier, bigger and nicer 100hp tractor with powershift from Kubota, NH, Case, and MF.
   / John Deere 2013-2015, 5E series brake problem? #60
My bad. I saw the 5083E Limited on the list that was posted and assumed that it was included. My previous tractor was a 5045D and it was flawless.
In Texas, JD competes very well. My 5083E was way less than a comparable unit from NH or Kubota. Plus I have a green dealer less than 5 miles from the house.
Miller Bobcat 250D Welder (A57453)
Miller Bobcat 250D...
Deere 325G (A57148)
Deere 325G (A57148)
2017 CAT 315F LCR EXCAVATOR (A58214)
2017 CAT 315F LCR...
2012 INTERNATIONAL DURASTAR 26FT NON CDL BOX TRUCK (A56138)
2012 INTERNATIONAL...
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
