John Deere 2013-2015, 5E series brake problem?
   / John Deere 2013-2015, 5E series brake problem? #1
LoudonNH
Bronze Member
Culpeper, Virginia
2017 JD5100M, 2014 JD5075E, 2017 JD3039R, 2023 JD X730
This is a subject we've been discussing in rustyshackleford's thread about the problems he's had with his new 5E series tractors. I have had a similar problem with my new tractor.
Simply stated, when I push the brake pedals on my 2014 5075E tractor, they go straight to the floor and do not provide enough braking to stop the tractor. With the second and subsequent pushes, the brakes work nicely. If I don't use the brakes again within a few seconds, the pedals go to the floor again. My dealer and apparently John Deere also, say this is normal and within specs for my tractor.
I'd like to get an idea how many other owners of the 5055E, 5065E and 5075E tractors of model years 2013-2015 are experiencing this problem. This forum is just a start, as most owners do not participate here, but it should be a good place to begin. I don't know if this problem is specific to the cab models and will be interested to learn more from your responses.
I intend to address this problem directly with John Deere, as they have apparently limited the amount of support they are willing to authorize my dealer to provide; it took several weeks for my dealer to get authorization from JD to come out and test the brake system pressure, and that's apparently all they gave him the ok to do. My dealer has been very responsive to my needs , but without any instructions or reimbursement from JD, I understand why he cannot provide any further help with this problem.
The legal advice I got is to gather as many other owners as possible to join in my claim. I am also going to contact OSHA for help and if necessary, the state's attorney general's office. My tractor is not safe to operate. My insurance carrier has assured me I would be covered in the event of an accident but that with the information I've provided so far, they would subrogate any claim against John Deere. I have the impression JD is ok with that and can only guess it's because finding and implementing a solution to the problem would cost them more.
   / John Deere 2013-2015, 5E series brake problem? #2
As we have talked about on the other tread I am glad I don't have this problem with my 2012 5045E. I still want to know what is different in the parts list between my tractor and yours as far as the brake assembly goes. I suspect the answer lies there.
I wish you the best of luck resolving this issue. For the amount of money we pay and with the years of experience they have building tractors there is no reason why any of our new tractors should have ANY issue with brakes.
Yes! You make a very good point. One would think brakes should have been perfected many years ago, so that every new tractor would come with good brakes today.
   / John Deere 2013-2015, 5E series brake problem? #4
I bought a 2013 5075E this past November. New, old stock, 0 hours, full warrenty. I too am not satisfied with the brakes on my unit which has 16 hrs on it now. The brakes will not "bottom out" but will travel at least 3/4 of the way down before any noticable slowing/stopping happens. Pumping the pedal does provide effective stopping. The service manager at the dealership where I bought the machine told me this was "normal" and could not be fixed or adjusted out with "bleeding" the system. How much travel will the pedal have after a few hundred or thousand hours. I may follow through and get some documentation and this for my own safety.
   / John Deere 2013-2015, 5E series brake problem? #5
I purchased a 2014 5055E cab unit 3 weeks ago. Researching which model to buy I spent quite a few hours on Green tractor talk and this forum and due to comments regarding issues with brakes and melting fuel tanks on the 5E series test drove several and spoke with numerous dealers on these issues. Every 5055 I drove had what I would call "soft brakes", far less responsive than on my Kubota. The selling dealer assured me 'my' brakes had been serviced and worked fine before the tractor was delivered to my son's home, and I've only driven it around his lot since purchase. The brakes go down 3-4 inches before slowing occurs on the first pump; the second pump is quite firm and hardly depresses at all but solidly engages and stops the tractor. I will take it it camp this weekend and work it a few days and will certainly pay attention to how they work. I warned the dealer beforehand I would return the tractor if I had problems with the brakes. If they don't function adequately to operate safely in steep or timbered terrain I will certainly let you know. While they may safely function according to Deere standards they are not comparable to the Kubota.
   / John Deere 2013-2015, 5E series brake problem? #6
My 2014 5075 cab has the same problem. The dealer has looked at it twice and bled the brakes both times to no avail. They stated the brakes are working normally. They further advised me this is their answer to the sticking brakes problem with the older models. No, I don't like the way they work. It seems like an accident waiting to happen.
This is very good. I didn't expect so many responses in just the first few hours of this thread!
Beanbag, I will look at the Green Tractor Talk Forum to see what I can learn there. Maybe we can find more owners with similar problems on that forum.
I hope any 5E series owners that have had accidents or mishaps because of inadequate brakes will join us as well.
Trook, I have heard that as well, that the first tractors in this series had issues with the brakes locking-up. I was told Deere's solution was to make the brakes work the way they do now; very inadequate and unsafe in my opinion.
Let's hope Deere will be willing to correct this problem, after enough of us have shared our experiences with the questionable brakes on these tractors.
Thank you all for staying on topic here.
   / John Deere 2013-2015, 5E series brake problem? #8
I have a 2014 5065e, the brakes do travel down farther on the first push than on subsequent pushes, but even the first push stops the tractor well.... So far at least.
   / John Deere 2013-2015, 5E series brake problem? #9
Here is the list of all the tractors that I posted on the other thread that utilize the same brake valve. JD has not changed the brake valve much since the introduction of the 1020/2020 tractors. This valve is a manual brake valve supplied with oil from the hyd system.
2332 - 5200, 5300, 5400 and 5500 Tractors - 22Mar15 ( FR ES )
2615 - 5210, 5310, 5410 and 5510 Tractors - 22Mar15 ( FR ES )
2616 - 5310N and 5510N Tractors - 22Mar15 ( FR ES )
2845 - 5320N, 5420N and 5520N Tractors - 17Jul14 ( FR ES )
4413 - Tractors 5215, 5315, 5415, 5515, 5515 High Crop (European Edition) - 14Oct14 ( FR DE IT ES SV )
4414 - Tractors 5215F&V, 5315F&V, 5515F&V, 5615F&V (European Edition) - 14Oct14 ( FR DE IT ES SV )
4416 - 5303, 5403 and 5503 Tractors (PY5303E,PY5403E,PY5503E)(Turkey Version) - 22Mar15 ( TR )
4421 - 5310 (S.N. PY5310S005119- ) and 5203S (S.N. PY5203S000001 -) Tractors (India Edition) - 21Mar15
4433 - 5310S(PY5310T), 5410(PY5410S), 5610(PY5610T) Tractors (India Edition) - 21Mar15
4465 - 5303(PY5303C) and 5403(PY5403C) Tractor (North Africa Version) - 21Mar15
4469 - 5310,5610 (PY5310S,PY5610T) Tractors (Asian Edition) - 22Mar15
4476 - 5303 (PY5303E) and 5403(PY5403E) Tractors (South Africa Version) - 21Mar15
4480 - 5103, 5203, 5303 and 5403 Tractors (PY5103A,PY5203A,PY5303A,PY5403A)(Australia Edition) - 21Mar15
4481 - 5303 and 5403 (PY5303L, PY5403L) Tractors (South American Edition) - 21Mar15 ( PT ES )
4482 - 5303, 5403, 5503 Tractors (PY5303E,PY5403E,PY5503E) European Edition - 21Mar15 ( TR )
4501 - 5045D, 5045E, 5055D, 5055E, 5065E, 5075E Tractors (Engine: 3029TPY41, 3029TPY45, 3029TPY46, 3029TPY48)(North American 8X4/9X3 Transmission with OOS) - 22Mar15 ( FR ES )
4530 - 5100M Tractor (European Edition) - 22Jan15 ( FR DE IT ES SV )
4533 - 5045D,5045E,5055D,5055E,5065E,5075E Tractors (PY-5045B,5045U,5055B,5055U,5065U,5075U)(Australian 8X4/9X3-OOS Version) - 21Mar15
4534 - 5-750,5-754,5-800,5-804,5-850,5-854,5-900 Tractors, Manufactured by Tiantuo (NF) (China Edition) - 27Sep10
4538 - 5055E, 5065E and 5075E Tractors (European/Australian 9X3TSS-IOOS Version) - 22Mar15 ( FR DE IT PT ES )
4588 - 5070M Tractors (European Edition) - 22Jan15 ( FR DE IT ES SV )
4589 - 5080M Tractors (European Edition) - 22Jan15 ( FR DE IT ES SV )
4590 - 5090M Tractors (European Edition) - 22Jan15 ( FR DE IT ES SV )
4716 - 5055E Tractor (Engine 3029HPY36) (India Edition) - 21Mar15
4717 - 5060E Tractor (Engine 3029HPY37) (India Edition) - 21Mar15
4718 - 5065E Tractor (Engine 3029HPY38, 3029HPY49) (India Edition) - 21Mar15
4719 - 5075E Tractor (Engine 3029HPY39, 3029HPY50) (India Edition) - 21Mar15
6077 - 5415, 5415H, 5615, 5715 and 5715HC Tractors - 21Mar15 ( ES )
6081 - 5415 Narrow Tractor - 30Jan15 ( ES )
6088 - 5425(S.N.-002631), 5625(S.N.-001688) and 5725(S.N.-005047) Tractors (Manufactured in Monterrey) - 21Feb15 ( ES TR )
6101 - 5425(S.N. 002632-), 5625(S.N. 001689-) and 5725(S.N. 00504:cool: Tractors (Manufactured in Monterrey)(Worldwide Edition) - 30Jan15 ( ES TR )
6105 - 5083E Tractor (Engine 4045HP058)(Mexico Edition) - 22Mar15 ( FR IT ES TR )
6106 - 5093E Tractor (Engine PE4045HP059) - 21Mar15 ( FR IT ES TR )
6120 - 5076E Tractor (Worldwide Edition) - 22Mar15 ( FR PT RU ES )
6121 - 5076EL (Orchard) Tractor (Worldwide Edition) - 22Mar15 ( FR PT RU ES )
6122 - 5076EF (Narrow) Tractor (Worldwide Edition) - 22Mar15 ( FR PT ES )
6123 - 5082E Tractor (Worldwide Edition) - 22Mar15 ( FR PT RU ES )
6124 - 5090E Tractor (Worldwide Edition) - 22Mar15 ( FR PT RU ES )
6125 - 5090EL (Orchard) Tractor (Worldwide Edition) - 22Mar15 ( FR PT RU ES )
6126 - 5090EH (High Clearance) Tractor (Worldwide Edition) - 22Mar15 ( FR PT RU ES )
8543 - Tractor 5055E (South American Edition) - 03Feb15 ( FR PT ES )
8544 - Tractor 5065E (South American Edition) - 16Feb15 ( FR PT ES )
8548 - Tractor 5078E (South American Edition) - 16Feb15 ( FR PT ES )
8549 - Tractor 5085E (South American Edition) - 16Feb15 ( FR PT ES )
9197 - 5605 and 5705 Tractors - 04Aug14 ( PT ES )
9309 - 5103, 5203, 5303 and 5403 Tractors (PY5103U,PY5203U,PY5303U,PY5403U)(North American Edition) - 21Mar15 ( FR ES )
9310 - 5204(PY5204A) and 5303(PY5303M) Tractor (Mexico Version) - 21Mar15 ( ES )
9424 - 5220 and 5320 Tractors - 22Mar15 ( FR ES )
9425 - 5420 and 5520 Tractors - 22Mar15 ( FR ES )
9558 - 5600, 5700 Tractors (South America) - 03Feb15 ( PT ES )
9645 - 5603 Tractor - 22Mar15 ( FR ES )
9669 - 5603 Tractor (South American Edition) - 04Aug14 ( PT ES )
9817 - 5101E Limited / 5101E Tractor (Engine 4045HLV56,4045TLV64) - 22Mar15 ( FR RU ES )
9818 - 5083E Limited / 5083E Tractor (Engine 4045HLV53,4045TLV56) - 22Mar15 ( FR RU ES )
9819 - 5093E Limited / 5093E Tractor (Engine 4045HLV54,4045TLV60) - 22Mar15 ( FR RU ES )
9945 - 5083EN Tractor (North American Edition) - 22Mar15 ( FR RU ES )
9946 - 5093EN Tractor (North American Edition) - 22Mar15 ( FR RU ES )
9947 - 5101EN Tractor (North American Edition) - 22Mar15 ( FR RU ES )
9955 - 5075E Tractor (South American Edition) - 06Mar15 ( FR PT ES )
9987 - 5303, 5403 Tractor (Mfg. in Brazil)(South American Edition) - 03Feb15 ( PT ES )
10540 - 5065M Tractor (Engine 5030HLV11)(IT4) - 22Mar15 ( FR IT PT ES TR )
10541 - 5075M Tractor (Engine 5030HLV11)(IT4) - 22Mar15 ( FR IT PT ES TR )
10542 - 5085M Tractor (Engine 4045HLV53,4045HLV54)(Tier 3) - 22Mar15 ( FR IT PT ES TR )
10543 - 5095M Tractor (Engine 4045HLV52,4045HLV55)(Tier 3) - 22Mar15 ( FR IT PT ES TR )
10544 - 5095MH Tractor (Engine 4045HLV52)(Tier 3) - 22Mar15 ( FR IT PT ES TR )
10545 - 5105M Tractor (Engine 4045HLV50)(Tier 3) - 22Mar15 ( FR IT PT ES TR )
10546 - 5105ML Tractor (Engine 4045HLV50)(Tier 3) - 22Mar15 ( FR IT PT ES TR )
10844 - 5325N Tractor - 18Nov14 ( FR ES )
10845 - 5425N Tractor - 22Mar15 ( FR ES )
10846 - 5525N Tractor - 22Mar15 ( FR ES )
10865 - 5225 Tractor - 18Nov14 ( FR ES )
10866 - 5325 Tractor - 18Apr13 ( FR ES )
10867 - 5425 Tractor - 22Feb15 ( FR ES )
10868 - 5525 Tractor - 22Feb15 ( FR ES )
10869 - 5625 Tractor - 22Feb15 ( FR ES )
10967 - 5400N Tractor - 18Nov14 ( FR ES )
10968 - 5500N Tractor - 18Nov14 ( FR ES )
11015 - 5085M Tractor (Engine 4045HLV68,4045HLV70)(iT4) - 22Mar15 ( FR ES )
11016 - 5100M Tractor (Engine 4045HLV68,4045HLV70)(iT4) - 22Mar15 ( FR ES )
11017 - 5100MH Tractor (Engine 4045HLV68,4045HLV70)(iT4) - 22Mar15 ( FR ES )
11018 - 5115M Tractor (Engine 4045HLV68,4045HLV70)(iT4) - 22Mar15 ( FR ES )
11019 - 5115ML Tractor (Engine 4045HLV68,4045HLV70)(iT4) - 22Mar15 ( FR ES )
11400 - 5090E Tractor (South American Edition) - 16Feb15 ( FR PT ES )
11532 - 5050E Tractor (Turkey Edition) - 21Mar15
11743 - 5055E Tractor (Engine: 3029TPY21, 3029TPY38, 3029TPY50) (North American Edition, 9X3 TSS and 12X12 PR Transmission) - 21Mar15 ( FR ES )
11744 - 5065E Tractor (North American Edition, 9X3 TSS and 12X12 PR Transmission) - 21Mar15 ( FR ES )
11745 - 5075E Tractor (North American Edition, 9X3 TSS and 12X12 PR Transmission) - 22Mar15 ( FR ES )
11746 - 5055E Tractor (For Europe, Australia and New Zealand; 9X3 TSS and 12X12 PR Transmission) - 21Mar15 ( FR DE IT PT ES )
11747 - 5065E Tractor (For Europe, Australia and New Zealand; 9X3 TSS and 12X12 PR Transmission) - 21Mar15 ( FR DE IT PT ES )
11748 - 5075E Tractor (For Europe, Australia and New Zealand; 9X3 TSS and 12X12 PR Transmission) - 21Mar15 ( FR DE IT PT ES )
11913 - 5050E Tractor (Indian Edition) - 21Mar15
11933 - 5085E Tractor (Engine: 4045HLV69, iT4)(North American Edition) - 22Mar15 ( FR ES )
11934 - 5100E Tractor (Engine: 4045HLV69, iT4)(North American Edition) - 22Mar15 ( FR ES )
11983 - 5045E Tractor (Engine:3029HYP61, Final Tier 4)(North American Edition) - 22Mar15 ( FR ES )
11984 - 5055E Tractor (Engine:3029HYP61, 3029HPY62, Final Tier 4)(North American Edition) - 22Mar15 ( FR ES )
11985 - 5065E Tractor (Engine:3029HYP61, 3029HPY62, Final Tier 4)(North American Edition) - 22Mar15 ( FR ES )
11986 - 5075E Tractor (Engine:3029HYP61, 3029HPY62, Final Tier 4)(North American Edition) - 22Mar15 ( FR ES )
12050 - 5085M Tractor (S.N. 500001- )(Engine 4045HLV70)(European Edition) - 22Mar15 ( NL FI FR DE IT PT ES SV TR )
12051 - 5100M Tractor (S.N. 500001- )(Engine 4045HLV70)(European Edition) - 22Mar15 ( NL FI FR DE IT PT ES SV TR )
12052 - 5115M Tractor (S.N. 500001- )(Engine 4045HLV70)(European Edition) - 22Mar15 ( NL FI FR DE IT PT ES SV TR )
12179 - 5085ML Tractor (Engine 4045HLV68,4045HLV70)(North American Edition) - 22Mar15 ( FR ES )
12180 - 5100ML Tractor (Engine 4045HLV68,4045HLV70)(North American Edition) - 22Feb15 ( FR ES )
12211 - 5075M Tractor (European Edition)(Engine 3029HPY65, Final Tier 4) - 14Dec14 ( FR DE IT PT ES TR )
12226 - 5055E Tractor (South Africa and MENA Edition, Engine: 3029TPY26, 3029TPY42) - 21Mar15
12227 - 5065E Tractor (South Africa and MENA Edition, Engine: 3029TPY27, 3029TPY43) - 21Mar15
12228 - 5075E Tractor (South Africa and MENA Edition, Engine: 3029TPY28, 3029TPY44) - 21Mar15
12256 - 5075EF Tractor (Engine: 3029TPY60)(South American Edition) - 06Mar15 ( PT )
12272 - 5055E Tractor (JD Asia and Central Africa Edition, Engine: 3029DPY01) - 22Mar15 ( FR PT )
12302 - 5045E Tractor (Engine 3029TJ002)(CKD Argentina Edition) - 22Mar15 ( ES )
12303 - 5065E Tractor (Engine 3029TJ003, 3029TPY39)(CKD Argentina Edition) - 22Mar15 ( ES )
12304 - 5075E Tractor (Engine 3029TJ004, 3029TPY40)(CKD Argentina Edition) - 21Mar15 ( ES )
12306 - 5085E Tractor (Engine 4045HLV69)(European Edition) - 22Mar15 ( NL FI FR DE IT PT ES SV TR )
12307 - 5095E Tractor (Engine 4045HLV69)(European Edition) - 22Mar15 ( NL FI FR DE IT PT ES SV TR )
12397 - 5075M Tractor (North American Edition)(Engine:3029HYP65)(Final Tier 4) - 14Dec14 ( FR ES )
12536 - 5060E Tractor (Engine 3029HPY71) (India Edition) - 31Mar15
12537 - 5065E Tractor (Engine 3029HPY72) (India Edition) - 31Mar15
12538 - 5075E Tractor (Engine 3029HPY73) (India Edition) - 31Mar15
12563 - 5085M Tractor (Engine 4045HLV72)(North American Edition)(FT4) - 22Mar15 ( FR ES )
12564 - 5100M Tractor (Engine 4045HLV72)(North American Edition)(FT4) - 22Mar15 ( FR ES )
12565 - 5115M Tractor (Engine 4045HLV72)(North American Edition)(FT4) - 22Mar15 ( FR ES )
12566 - 5100MH Tractor (Engine 4045HLV72)(North American Edition)(FT4) - 22Mar15 ( FR ES )
   / John Deere 2013-2015, 5E series brake problem? #10
I have a 2014 5065E 4x4 with cab that has the same issue as everyone else. Talked to the dealer about it and they said they haven't heard of anything about the brake issue. Should have went with a CASE. My Grandpaw always told me t o never buy green. He's probably turning over in his grave.
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A52128)
2006 Magnolia Dry...
2013 Ford Escape SUV (A50324)
2013 Ford Escape...
Land Honor Skid Steer Pallet Forks (A50515)
Land Honor Skid...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A52141)
2018 FREIGHTLINER...
2016 BOBCAT T590 SKID STEER (A51242)
2016 BOBCAT T590...
