John Deere 145 Mower Deck will not engage
/ John Deere 145 Mower Deck will not engage #1
bsm1550
Georgia
John Deere 145
JD 145 mower deck does not engage. Motor runs fine, but when you attempt to engage blades nothing happens.
/ John Deere 145 Mower Deck will not engage #2
is that the JD 145 lawn tractor ?
I have a JD160, and when that happens - as it does occasionally, I check that all of the mower belts are still in working order (mine has 3 belts). other possibility is that the blades are obstructed ... grass, dirt, plastic bag (or in my case last week - a large carpet fragment that was buried in long grass). immediately shut the machine off, clear any obstructions on the blades, check that the belts are all present and accounted for... then try engaging the mower again. maybe that will solve it. in the meantime, briefly running the engine shouldn't hurt, but don't engage the mower.
fuse under the toggle switch ?
/ John Deere 145 Mower Deck will not engage #3
On my JD285 the wires to the mower drive clutch broke where they entered the clutch. Had to buy a new one, no way to fix the old one.
/ John Deere 145 Mower Deck will not engage #4
Seat switch open, Parking brake on. Blown fuse. Bad clutch coil. Broken wire. Broken, missing or jumped intermediate drive belt. Broken, missing or jumped belt on mower deck.
Listen to hear a clutch 'clacking' noise with the engine off and mower engagement selected. If nothing, then its electrical.
/ John Deere 145 Mower Deck will not engage #5
My JD 325 ...mower will not engage ...motor runs fine ...any one know how to get a wiring diagram.
I checked Fuses ...interlock Switches are fine..
