Oil & Fuel John Deere 112L Hydrostat issues
/ John Deere 112L Hydrostat issues #1
afreeman42
Attica, OH
John Deere 112L
I have an 85 JD 112L that was given to me by my father in law. When i got it, it was missing the hydro drive belt, so i put one on, and when started it initially would barely move. After letting it run for about 10 minutes, the trans worked with no issues. I mowed with it half a dozen times, and the last time i mowed, when i was almost done with the yard it started having the same issue. It moves, but very slowly. So i parked it for the winter. This spring, i got it out and drained the tranny fluid, which you could tell definitely needed to be changed. I got more fluid from JD, but when i went to put the new fluid in, some of the old fluid was still filling up the filler neck. Can someone tell me what i am missing here? Any help is appreciated!
/ John Deere 112L Hydrostat issues #2
Hopefully someone more knowledgeable will chime in but some of the hydrostatic transmission won't drain all the fluid out because it is compartmented. It may need to be removed and turned over to fully drain and refill. By the same note make sure you get the correct amount of fluid back in it too.
2020 Takeuchi TL8R2 (A64126)
2020 Takeuchi...
EZ-GO Electric Golf Cart (A60462)
EZ-GO Electric...
2009 Kubota M108S (A60462)
2009 Kubota M108S...
2022 Caterpillar 299D3 (A64126)
2022 Caterpillar...
2019 FORD F-550 SUPER DUTY (A65643)
2019 FORD F-550...
2010 WABASH 53X102 REFRIDGERATED TRAILER (A59914)
2010 WABASH 53X102...
