Backhoe John Deere 110 TLB Main Backhoe Bucket Pivot Pin - How do you remove these?
   / John Deere 110 TLB Main Backhoe Bucket Pivot Pin - How do you remove these? #31
I went ahead and ordered a DeWalt gun and a LockNLube tip, along with their grease buster. I'm hopeful that between those three I'll also be able to "crush through those tight sticky pins."
Anybody have strong feelings on grease? I always buy graphite grease from Harbor Freight and it seems to last just as long as anything else I've tried. Seems to me that the trick is to grease often and that the brand doesn't matter so much.
   / John Deere 110 TLB Main Backhoe Bucket Pivot Pin - How do you remove these? #32
I use this Lucas Xtra Heavy Duty Green Grease......
   / John Deere 110 TLB Main Backhoe Bucket Pivot Pin - How do you remove these? #33
I agree!
Grease brand does not matter nearly as much as frequency.
   / John Deere 110 TLB Main Backhoe Bucket Pivot Pin - How do you remove these? #34
My DeWalt grease gun arrived last week, and I'm impressed. I'd just cleaned up my stuck zerk fittings, so no need to power through a clogged one, but the gun seems to be high-quality and it's easy to use. I added a Locknlube fitting, and I like that too.
BUT.... to get back to the subject: I wonder if the OP ever got his pin unstuck......
   / John Deere 110 TLB Main Backhoe Bucket Pivot Pin - How do you remove these? #35
I agree!
I would agree with that. Although there is a guy on YouTube(Project Farm), this guy does some really interesting research. One of his videos shows the differences in greases and surprisingly enough there is a difference. Now at what price is it worth it? That is the question. I think most wear and failures are from lack of maintenance anyway so grease and grease often.
   / John Deere 110 TLB Main Backhoe Bucket Pivot Pin - How do you remove these? #36
I was going to buy the "LockNlube but was afraid the setup would be to **** long. Do you have a opinion yet? The stock one from DeWalt seems to hold pretty well so far but I like the idea of the LockNlube.
   / John Deere 110 TLB Main Backhoe Bucket Pivot Pin - How do you remove these? #37
The Lock-N-Lube is a very worthwhile device.
Does not add much length
UNUSED SET OF FUTURE 13', 200AMP JUMPER CABLES (A57192)
UNUSED SET OF...
1995 Koehring LRT-110 7.5 Ton 4WD Rough Terrain Crane Truck (A55787)
1995 Koehring...
2019 Ford F550 (A55973)
2019 Ford F550...
2012 Volkswagen Tiguan AWD SUV (A55853)
2012 Volkswagen...
UNUSED FUTURE PG72 72" HYD PLATE GRABBER (A57193)
UNUSED FUTURE PG72...
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
