Backhoe John Deere 110 TLB Main Backhoe Bucket Pivot Pin - How do you remove these?
   / John Deere 110 TLB Main Backhoe Bucket Pivot Pin - How do you remove these? #11
Almost looks like it's been welded in place (picture on the left). Is the thumb a Deere accessory or added later?
That's just the flange of the pin. It can't go out from that side. Only from the other side (right picture).
   / John Deere 110 TLB Main Backhoe Bucket Pivot Pin - How do you remove these? #12
That pin will come out, but needs some meaningful hydraulic force to push on it from the side with the bolt hole.
   / John Deere 110 TLB Main Backhoe Bucket Pivot Pin - How do you remove these? #13
Maybe weigh the potential outcomes from just leaving it in place.. ?
Thanks everyone.
We are now pretty sure that our pin should have a 1/2 inch bolt and large flat washer on the side with the internal threaded hole (see picture)... I'm guessing that it's been missing for some time, and the only thing holding the pin in is that it's stuck.
We're going to replace those before trying to get the pin out...
   / John Deere 110 TLB Main Backhoe Bucket Pivot Pin - How do you remove these? #15
Thanks everyone.
So...you think replacing the bolt and washer will help you get the pin out?
Ain't gonna happen!
The washer and bolt, when they are there, obviously act as a pin retainer!
   / John Deere 110 TLB Main Backhoe Bucket Pivot Pin - How do you remove these? #16
I would try using a high pressure electric grease gun. The DeWalt puts out 10,000psi. That thing is incredible for stuck pins.
   / John Deere 110 TLB Main Backhoe Bucket Pivot Pin - How do you remove these? #17
^^^^^^ GOOD ADVICE!
   / John Deere 110 TLB Main Backhoe Bucket Pivot Pin - How do you remove these? #18
   / John Deere 110 TLB Main Backhoe Bucket Pivot Pin - How do you remove these? #20
Try a little heat when pumping the grease in .......
2009 Dodge Ram 3500 Flat bed (A55973)
2009 Dodge Ram...
2007 Ford Five Hundred SEL Sedan (A54815)
2007 Ford Five...
John Deere 1025R (A53317)
John Deere 1025R...
2020 DRAGON 150BBL ALUMINUM (A58214)
2020 DRAGON 150BBL...
2015 Ford Transit Cargo Van (A54814)
2015 Ford Transit...
2019 CHEVROLET SILVERADO 11FT FLATBED (A57880)
2019 CHEVROLET...
