V1BuzzBomb
While under machine inspecting, found a couple of things.
First, the rear lower loader boom tower bolts were loose. There are four per side. The fronts are easy to inspect and tighten. The rears are a PITA, especially with a cab. I've seen the nightmares here if they loosen and get out of hand. I tightened them to 150 ft/lbs. Does anyone know the factory torque spec?
Secondly, It appears that the loader boom hard lines under the driveline are bent. I received the machine like this. Someone must have driven over something and got one or both caught. They don't leak and I'm uncertain if I try to straighten if they might. I suppose that it is mostly a cosmetic issue, although, there is a slight kink in one pipe out of the front of the diverter. That may slighty restrict flow. I may be able to confirm original pipe shape/bends with image from machine without similar issue. Image of loader boom piston hard lines under driveline, diverter and forward.
