John Deere 110 TLB hydraulic temp sensor
   / John Deere 110 TLB hydraulic temp sensor #1
MH110
CA
John Deere 110 TLB
Does anyone know the location of the hydraulic oil temperature sensor on the older, first generation 110痴?
The manual and parts diagrams both say its on the filter housing, but the early models had no filter housing, it was just straight-piped instead of using the huge RE45864 filter and housing.
Thanks!
   / John Deere 110 TLB hydraulic temp sensor #4
Mine shows it being a spin on filter with the sensor in the housing.
What痴 your S/N? The earlier ones didn稚 have the spin on filter or housing, it was just straight-piped, so not sure where the sensor would be then!
   / John Deere 110 TLB hydraulic temp sensor #6
Are you looking for the temp sensor or the restriction sensor?
I’m looking for the temperature sensor.
   / John Deere 110 TLB hydraulic temp sensor #8
Did you ever find the hydraulic oil temperature sensor? I知 having the same issue.
2012 CHEVROLET SILVERADO 1500 (A58214)
2012 CHEVROLET...
SET OF ALUMINUM RAMPS (A58374)
SET OF ALUMINUM...
202479 (A54757)
202479 (A54757)
2017 Ford F-350 Ext. Cab Pickup Truck (A56858)
2017 Ford F-350...
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A55973)
2012 Freightliner...
2013 MACK CHU613 (A58214)
2013 MACK CHU613...
