John Deere 110 TLB hydraulic temp sensor
   / John Deere 110 TLB hydraulic temp sensor #1
MH110
CA
John Deere 110 TLB
Does anyone know the location of the hydraulic oil temperature sensor on the older, first generation 110痴?
The manual and parts diagrams both say its on the filter housing, but the early models had no filter housing, it was just straight-piped instead of using the huge RE45864 filter and housing.
Thanks!
   / John Deere 110 TLB hydraulic temp sensor #4
Mine shows it being a spin on filter with the sensor in the housing.
What痴 your S/N? The earlier ones didn稚 have the spin on filter or housing, it was just straight-piped, so not sure where the sensor would be then!
   / John Deere 110 TLB hydraulic temp sensor #6
Are you looking for the temp sensor or the restriction sensor?
I’m looking for the temperature sensor.
   / John Deere 110 TLB hydraulic temp sensor #8
Did you ever find the hydraulic oil temperature sensor? I知 having the same issue.
1969 Lincoln Continental Mark III Sedan (A56859)
1969 Lincoln...
Hydraulic rail grinder (A56436)
Hydraulic rail...
2017 BX2680 Sub Compact Utility Tractor (A56436)
2017 BX2680 Sub...
40ft High Cube Shipping Container (A57453)
40ft High Cube...
(1) HD 24ft Free Standing Corral Panel (A57454)
(1) HD 24ft Free...
1990 35 Ton Phelan Low Boy (A57453)
1990 35 Ton Phelan...
