John Deere 110 TLB Bleeding Fuel System
/ John Deere 110 TLB Bleeding Fuel System #1
threepiece
Farmington, Mi
Kubota L3400 John Deere110 TLB Wheelhorse 520H
I ran my 110 out of fuel recently . According to the service manual the system is self bleeding so I thought I would simply add fuel and go. This was not the case. After refueling, the engine would start after a considerable amount of cranking and then for only a few seconds. I repeated this several times before I began to investigate. After checking for water and a few other things I noticed gas (presumably air) escaping when I loosened the spin on fuel filter. I'm not sure if it was pressure or vacuum. After retightening the filter the engine started and ran good.
I understand there are at least two fuel systems found on the 110's. As I understand one type does not use the spin on fuel filter.
I hope this helps someone.
/ John Deere 110 TLB Bleeding Fuel System #2
Thanks for the info.
I'm going to change my fuel filter this fall. Hopefully it will be easy!
Little did I know this post would help me years later. Again having the same issue. A search for similar problems revealed my old post that helped a bunch LOL!
