John Deere 110 loader backhoe surging in fwd and reverse
   / John Deere 110 loader backhoe surging in fwd and reverse #11
I believe it has a single wire connected.
If I had the 110 here I would go out and look.
Memory is right side down around the floor board and bolted to the flywheel housing.
   / John Deere 110 loader backhoe surging in fwd and reverse #12
Okay, thanks. I found where it was supposed to be. My model has nothing in that socket and the pigtail is capped off. I purchased the machine new in 2007 so I'm suspecting it's a 2006 model. Anyone know what JD replaced this function with?
My symptoms are slightly different from that described in this thread but not entirely. My 110 TLB lurches erratically in any gear, 4x2 or 4x4, pedal or creep controls, but only in forward motion. Reverse seems fine.
   / John Deere 110 loader backhoe surging in fwd and reverse #13
Sorry it was not the answer since us Deere 110 tlb owners have to stick together!
Mine is a little older than yours and I didn't know there was a running change... maybe the part was superseded/eliminated as an improvement?
   / John Deere 110 loader backhoe surging in fwd and reverse #15
Ha. IMHO, the only improvement JD made to the 110 TLB was to discontinue it!:2cents:
Then sell it, there seems to be lots of people looking for them. Or you can fix the problem and get many good years of use from it. I have not had to replace mine on a 2005 model but the speed sensor isn't expensive to replace.
   / John Deere 110 loader backhoe surging in fwd and reverse #16
I paid $50k for it new and I've put $30k in repairs alone. The tranny bell housing has broken twice (the first time they partially covered it under warranty owing to a design flaw in the stabilizer arms bolts tending to loosen); the second time it was on my dime. I have always performed the recommended maintenance. Maybe I worked it too hard and need a larger machine but anyhow, I need to located that speed sensor on this model so I can replace it... if it has one.
   / John Deere 110 loader backhoe surging in fwd and reverse #17
I have located the speed sensor. It's on the transaxle housing, front left. I disconnected it and it didn't surge as much. The dash light now blinks ..._
   / John Deere 110 loader backhoe surging in fwd and reverse #18
Thanks for posting to get the information on variations out to the public...
Except for my speed sensor... no issues with my 110. I did buy it used so I am not the first owner.
I would not be too happy if had 30k in repairs either... which is more than I paid for mine.
   / John Deere 110 loader backhoe surging in fwd and reverse #19
Is there a list of JD error code definitions publicly available?
   / John Deere 110 loader backhoe surging in fwd and reverse #20
The fault code I'm getting is Beethoven's 5th: short-short-short-long
2014 Volkswagen Touareg - Turbo Diesel - AWD - 189,609 miles (A55302)
2014 Volkswagen...
78" ROCK BUCKET (A52706)
78" ROCK BUCKET...
VINTAGE EVINRUDE OUTBOARD MOTOR (A58374)
VINTAGE EVINRUDE...
RIPPER ATTACHMENT FOR MINI EXCAVATOR (A58216)
RIPPER ATTACHMENT...
FIMCO 25 GALLON SPRAYER, 3PT (A58374)
FIMCO 25 GALLON...
NEW Woods Reverse Rotation 5ft Tiller (A55301)
NEW Woods Reverse...
