John Deere 110 Compact TLB
Status
Not open for further replies.
/ John Deere 110 Compact TLB #121
OkieG
I was in a wood area today cutting alittle path for a neighbor. The 110 is a nimble machine, I was able to get around well with out damaging the the large trees I was manuvering around. I did get hungup on a steep slope though not anyware close to being with out movement. The challenge was not to dig up a nature landscape. The idea was to cut the crest of a hill off, place that material in a low spot to facilitate getting up and down the slope easier. All without tearing up a most beautiful place. Did the job well. This is a place that a larger machine would not have been able to go.
I have not dug a stump yet, though I see no problem with doing so. In the past I have dug alot of stumps, some that end up on being blasted out of the ground. Some of them were burts that I did dig with a machine that was about the size of the 110 much less sophisticated and much older machine [1959]. Dig wide and leave enough of the stump to push on.
The largest I recall was a 17' in circumfrace, so imagine what the root ball looked like. That was done with a 4500 Ford that had a large hoe. The bucket was 54'' from tooth to back of bucket kind of a diagonal measurement. That bucket was always dragging on the ground. The 110 bucket tucks up out of the way.
I have no intensions of digging big one anymore. I always felt that stumps were alot of strain on the machines. But I'm sure the 110 will dig a 1',2' stump with easy. That size I will continue to dig unless..... I were to use the stump grinder attachment that I've hear you can rent. I spoke to a JD dealer in Maine. He said that the grinders require a minimum of 12 gpm, he warned me not to be mislead. That the stump grinders require heafty flow, though I understand that bobcat skidsteer loaders have them available for their machines. The 110 comes with skidsteer attachment plates and hydralics are an option to the front loader. May be worth looking into if you have alot of stumps. My be just the reason to buy the 110. If you hear anything regarding stump grinding performance get back. Bushy....... Forgive my spelling and grammar.
/ John Deere 110 Compact TLB #122
Doug Smith
Here's another picture. Just open the attachment to the left. Bushy
/ John Deere 110 Compact TLB #123
Well,it has hit CT soil,even though the dealer was closed yesterday I swung by and there happened to be a salesman there,and lo and behold my 110 was there also,he walked me over to it,I gave it a good once over,yep,all options accounted for,he gave me the keys,took the ol' Phantom for a spin and a quick dig w/the hoe,a quick back-blade w/the loader,and put it back in its resting spot for the weekend.Of course it has to be pre-delivered still,but my salesman called me later to say he'd bring it home w/him on monday night and deliver it to my shop first thing tuesday morning....not gonna be gettin' much sleep the next couple of nights,but at least this whole ordeal is all most done,and I can start workin' stead of bitchin'!
/ John Deere 110 Compact TLB #124
Many thanks Bushy,
Keep em coming. You are our only link to this ghost they call the 110.
Tkanks again,
Doug
/ John Deere 110 Compact TLB #125
Tags,
After all thats taken place, are you SURE its your machine. Perhaps its JoeReal's machine and they delivered it to the wrong dealer....../w3tcompact/icons/wink.gif Afterall, that would be a fitting end to this story. Good luck Tags and happy tractoring!
Russ
/ John Deere 110 Compact TLB #126
That's right. That's probably my tractor. We Mainiacs are always the last to get anything.
/ John Deere 110 Compact TLB #127
Joe Real and Tags.......
In time you will have your machines and I believe that you will be happey with the 110. That skid plate might be a good investment. There is a lot of clearance under there but also a whole heap of plumbing. Be mindful of that when your in uncertain areas.
Even though my deal is struck I'm considering seeing if the dealer will through in a mirror, slow moving vehicle sign or a locking gas cap.
do they offer locking caps? The little bit I've been on the road a mirror would be useful.
Another thing I noticed recently, the 110 has brake lights. Yap, you apply the brakes and your back lights go on.
You guys are going to love the performance of the loader as well as the backhoe. That repositioning switch is the cats meow. I was doing some digging in a barn today some what tight, you don't want to bump any thing and I drove the tractor from the backhoe seat right out of the barn slick as a whisle. Did a three point turn. The joy stick and steer wheel well in reach. The powersteering is effortless.
With the backhoe I was able to dig right up to the edge of the siding of the barn and able to see the furthest point of the bucket. The closest I've been. That saves alot of hand work.
I'm looking forward to hearing from you guys regarding your performance comments when you get your's. Well can't wait till tomorrow, another day with the 110. Bushy
/ John Deere 110 Compact TLB #128
Bushy,
I did order mine w/the skid plate and the stabilizer gaurds,I would be afraid to use it especially w/out the skid plate,if a stick popped up or you highsided on a rock/stump it would be all over.....get the skidplate it is a $400 investment that could save you thousands of dollars and alot of swearing.One more sleepless night and I'll have it,when I saw it the other day I had forgotten how sweet it looked,I'm like a kid on x-mas eve!!
/ John Deere 110 Compact TLB #129
I must just have bad karma or somethin',or someone at Deere just hates me ALOT,because at this point this is beyond tollerable.I spoke w/ my salesman about noon today,he informed me of the following things...no 4n1 bucket,no 2' hoe bucket,and no 3 point hitch arms and top link,granted I was miffed,but he said they had a 2' bucket there that was compatable and they had a call in about the 4n1,and they had called Deere and the three point stuff is being overnighted,sounds good right????? WRONG,I then got a call from the salesman at about 5:30,he said that he had just left the dealership........ without my machine.He said there was a problem with a valve on the loader,he said that it would drift down when driving and also after the machine was shut off if the loader was in the air it would drift down,he said they found this out while doing the pre delivery checks.I told him when I ran the thing around on saturday there were no problems,he continued to tell me they "seem to be having a problem getting the part" right after hearing this I'm not sure what else he was saying because my blood had reached a temperature that I'm sure should have killed me.........then I attacked.........saying this has been the most !@#$%^& unpleasant experience I've ever !@#$%^ had,and that there is absolutely NO !@#$%& excuse for the machine to have come in w/out all the things I had ordered especially since it !@#$%& came in a month and a half later than the original date they had promised,someone should have been on top of that,they had PLENTY of time to confirm the order,BLAH,BLAH,BLAH.......So the end result is no 110 even though its at the dealer,but I do have a skid steer w/a harley rake comin' and a JD 50 excavator till I get it,which shows the dealer knows this is a BIG problem and is trying to help.My only problem now is I'm left wondering,whats going to go wrong with this thing next....is there anything else that can???
/ John Deere 110 Compact TLB #130
Hey Tags, was reading about a fella with a bad loader bucket on his 460 loader and came across this thread. My little bit of experience with the JD 110 was underwhelming at best. Its not a bad little TLB, just seems like a lot of gloss and glimmer but no real potency. Maybe I've just been running my JD 210 and JD 310/hoe to long and just can't downsize. The bang for the buck was missing. Maybe I just had a weak one. The hoe was nice, the loader a little weak and the hydrostatic drive just not enough. I'm sure it will be the bees knees for some folks though, just not for me. Hope it all works out for you, you did sound a bit frustrated. Hard to believe its taking you a month to get it. Saw a real interesting machine called a Earth Force 3 or 4 or 5 as I recall. The fella that was using it seemed rather new with it but man, it was one very smart little tractor. Part backhoe, part skidsteer and part tractor, its going to be real interesting to see if those show up on the jobs. I think its sort of a "jack of all trades" tractor but one that may do all the trades quite well.
/ John Deere 110 Compact TLB #131
I'm beginning to get realy bad feelings about J D and this machine. I wonder when mine will come in and how the set up will be and how many problems it will have. I don't deal very well with that kind of stuff . Being a Frenchman we can out- cuss anybody on the planet. At this moment, I wish I would have never started this process. Right now I don't need that kind of s_ _ _. Bushy did you not order yours with a 4in1 bucket? I hope there's better news next time I log on. I can only empathize with how you feel you Tags.
/ John Deere 110 Compact TLB #132
Tags. Did you at least get the skid plate and stabillizer bar?
I haven't heard a thing regarding my machine since they told me it was ready to ship. I don't even want to call anymore. Maybe they are shopping around for a 4n1 bucket to put on it before they ship it. Or maybe the delivery truck broke down and they can't find parts to get it back on the road. Oh well.
/ John Deere 110 Compact TLB #133
JoeReal
I originally ordered the HD with replacable cutting edge, mid stream I asked for a 4in1 and didn't make my mind up fast enough,so they couldn't acommadate at the factory, Later I was inform that it was not avaiable and have I been on time it would have delayed delivery of the tractor. Bushy
/ John Deere 110 Compact TLB #134
Okay, everybody the master mind is here with the pictures! And MORE information! Today, at approx. 4:15p I saw a semi heading southbound on I-75 below Dalton, Georgia with two (2) brand new 110s loaded. (Of course they where brand new) heh Well, also, I finally got my goofy camera working, and thanks to Doug's credit card, I got more than enough funds to buy a new camera plus hire some photographers to take the attached photos. Enjoy --
Remember my earlier lengthy post? These are the pics I claimed to have taken. Live in the byte for you NOW!
/ John Deere 110 Compact TLB #135
Good looking rig /w3tcompact/icons/cool.gif
/ John Deere 110 Compact TLB #136
Mr. M, can I get a membership upgrade since I went to all the trouble of taking these pics? /w3tcompact/icons/grin.gif /w3tcompact/icons/clever.gif /w3tcompact/icons/laugh.gif First, I had to conduct big time surveillance /w3tcompact/icons/clever.gif to even find this mysterious tractor that hardly anyone has seen; second, I had to acquire a dig. camera; third, I had to risk misdemeanor criminal prosecution by trespassing on private public property to sanp these photos;/w3tcompact/icons/cool.gif fourth, I had redo my whole comp system practically and pay a high tech comp tech to do it so I could post these!! (I'm really not kidding about that)/w3tcompact/icons/mad.gif/w3tcompact/icons/shocked.gif
Can I be gold now? or platinum, or something besides MEMBER????? -- that sounds so, uh, surgical. /w3tcompact/icons/hmm.gif /w3tcompact/icons/blush.gif
/ John Deere 110 Compact TLB #137
Did you notice the skid-steer type attachment hookup in the other photo . . .
Very practical.
/ John Deere 110 Compact TLB #138
Definitely was one of yours. I should have gotten the serial no.
/ John Deere 110 Compact TLB #139
the first shot -- out of focus, but better than nothing Tags and Le Joseph!
/ John Deere 110 Compact TLB #140
I don't know HK, I think you're holding out on us. Where are the tie downs? I think they're unloading that rig at your place! Sure is a pretty machine. Definitely beefier than the ag backhoes. Thanks for the pictures, let us know how it works /w3tcompact/icons/wink.gif
Status
