John Deere 1050 problem
/ John Deere 1050 problem #1
k4todave
Winchester, KY
My 1050 will not move. The rear wheels are locked up. For awhile, the wheels would hangup as I let out the clutch, then give a little "pop" and the tractor would drive and shift, etc. Now --- locked up tight. Any thoughts on what is the matter? Thanks. Dave in KY
/ John Deere 1050 problem #2
My first thought was whether you remembered to release the parking brake. My next thought was whether you have it in two gears at once somehow. Try moving your gear selector a bit.
Well the starter won't engage if either the hi/lo range or a gear is selected. So it is neutral for sure.
/ John Deere 1050 problem #4
I'm almost positive your brake cams are bound inside your drums. It's a pretty common problem. That pop sound you hear is usually them breaking free from the drum.
Replacing brake shoes on your Yanmar tractor
You can still get it into gear correct.. It just won't move and stall out when you release the clutch??
Case 580 Super E Backhoe Loader (A66285)
Case 580 Super E...
2018 GEHL RS5-19 GEN3 TELESCOPIC FORKLIFT (A65053)
2018 GEHL RS5-19...
Stertil Koni 18000lbs 4-Post Auto Lift (A61572)
Stertil Koni...
Landhonor TP2-13-08D Skid Steer Mount Tree Puller  (A62679)
Landhonor...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
