John Deere 1026 R
   / John Deere 1026 R #11
If it's an FEL that you are having the most trouble with when hooking back up, try this-
Take a floor jack and slide it under the torque tube cross member just behind the bucket that runs from one side of the loader frame to the other. Then, jack the tube up slightly to relieve the pressure in the roll back/dump cylinders. They are usually the culprit when it is hard to reattach the couplings, as the bucket will tend to roll back under it's own weight over time when stored, which in turn pressurizes the cylinders/lines. You can also just grab the torque tube and lift the bucket up by hand (the buckets/loader arms on the smaller units aren't so heavy that the average man can't lift them enough to relieve the pressure) a little and stuff some boards under it to hold it if you can't use a floor jack, or get one to where you're trying to hook back up at. Every JD FEL I have owned has had this same issue.
Good idea - the only caveat is you'd need a guy to lift the tube while the other plugs in the hoses - unless you make a shim stick to wedge it up. Still seems kind of dumb to have to do this - I just park the FEL in the corner with bucket flat where nobody can push on it. The park stand is stable enough as long as nobody pushes on it with the bucket flat.
   / John Deere 1026 R #12
Actually, I do this by myself somewhat regularly. But, I use a floor jack to simply raise the torque tube a small amount to relive pressure. Since the rollback causes some slack to be in the lines/cylinders/bucket connection, I can also raise the tube by myself enough to remove the slack and pressure and slide a few boards stacked up under the tube with one of my feet if I have to. I park my loader(s) on my smooth shop floor, but they still settle back (roll back) under their own weight over time, and it doesn't take that much time for them to roll back enough to cause pressure problems in the cylinders. In case someone is wondering, none of my loaders have been old and worn from high usage neither. They were bought brand new and did this from day one.
   / John Deere 1026 R #13
Ah - good idea, RG1. I am losing both my boys to scholastic activity shortly, so that's a good shortcut to use - hydraulic floor jack.
Thanks,
   / John Deere 1026 R #14
After shutting down the tractor and moving the joystick to all positions have you tried putting the loader stick in float mode. Float mode should relieve pressure from the up and down ports. When in float move the lever left and right again to relieve pressure on the curl mode ports.
   / John Deere 1026 R #15
Yes, but the question was why Deere's Manual says to set the bucket at an angle prior to this. If you move the joystick after shutdown, the bucket drops. If you don't, you have a pressurized tilt cylinder line. Makes no sense.
   / John Deere 1026 R #16
Agreed, no sense at all. Maybe JD tests their new FEL designs in a vacuum with zero gravity.:rolleyes:
Plus, as we've been discussing, it makes no difference how much you try to relieve pressure by working the joystick if it gets built up again while the FEL is removed.
   / John Deere 1026 R #17
The manual does make sense.
The reason for setting the bucket at the angle is to raise the front wheels of the tractor off of the ground, is to allow the latches to be opened. After the latches are open, it dose not mater what the bucket angle is, until the the loader is reinstalled & the latches need to be closed.
I have been using the process that George described, for many years. I do hold the joy stick in the dump positions for a few seconds or until the loader stops moving. Most times the bucket will settle to be flat on the floor.
   / John Deere 1026 R #18
Ah! So the only purpose is to remove mechanical pressure from the latch? OK, but if memory serves, the manual shows the removed loader with bucket angled on edge so..........???
   / John Deere 1026 R #19
In my manual, the only picture of the bucket angled, in the detach loader section, is before the loader is removed from the tractor. None of the pictures of after the loader is removed in that section show the front of the bucket.
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2012 DIAMOND T TRAILER TRAILER (A58214)
2012 DIAMOND T...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55302)
2015 Ford F550...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
