John Deere 1026 R
   / John Deere 1026 R #1
pniebieski
edgewater, fl
1026r John Deere
I have a John Deere 1026R tractor. From the get go I've had a tough time connecting the hydraulic connectors. I've tried many times too release the pressure in the lines to easily connect the cuppings but many times it wont work. Taken the tractor to John Deere but all I get is I have to release pressure.....It don't work .. any suggestions
   / John Deere 1026 R #2
I think it's important to relieve pressure before disconnecting (by shutting off tractor and toggling the lever to all possible positions). Then you would not have a buildup of pressure in the lines (other than maybe some thermal expansion, but that should be minor at ambient temps).
So that's my question -- are you doing anything to relieve pressure before disconnecting? That's the time when you can have an influence. Later on, when trying to reconnect, you can't do much but fight it and/or make a mess by manually popping the connect to let some fluid out.
   / John Deere 1026 R
That's the problem....I try all levers to release the pressure but most of the time I struggle to connect a connector....is there anything else I can do to release pressure
   / John Deere 1026 R #4
If there is a fitting available you can crack it very carefully as it will have pressure on it maybe wrap a rag around it to catch fluid hydraulic fluid under pressure is extremelydangerous and also movement can take place when pressure is released I think in previous thread it was mentioned after shutting down tractor move controls to relieve pressure not a bad idea.
some couplings are designed to hook up with some pressure you might check in to this option be careful
   / John Deere 1026 R #5
pop the balls on the connector with a soft hammer.
   / John Deere 1026 R #6
If you have an FEL, Deere's instructions are kind of screwy - they recommend putting the bucket up on edge, then releasing pressure - well, if you do that, the bucket drops. So what's the point?
I know what they're getting at - the self-standing FEL (quick-tatch) is better balanced on bucket edge when parked. But to do that, you have to disconnect at least one hydraulic line (tilt cylinder drain) under pressure. Which is both not good practice for the equipment, and really hard to re-connect (ask me how I know - took the golden shower releasing pressure when re-connecting).
I'd say forget what Deere is recommending, park the FEL someplace where kids can't jump on it, and disconnect with zero pressure on all cylinders. No problems.
Good luck!
   / John Deere 1026 R #7
I took the golden shower doing that! :irked:
   / John Deere 1026 R #8
Do you leave the loader outside when you take it off? The dealer showed me how to, after shutting the tractor off, move the joystick to all four positions and then do it again before unhooking the connections. Same before hooking it up. Works like a charm for me EXCEPT if I take the loader off outside and it sits in the sun. The hydraulic fluid will heat up enough in that case that's it's almost impossible to hook up the connectors. If I have to relieve pressure, I put a rag over the connector and tap it with a hammer.
   / John Deere 1026 R #9
If it's an FEL that you are having the most trouble with when hooking back up, try this-
Take a floor jack and slide it under the torque tube cross member just behind the bucket that runs from one side of the loader frame to the other. Then, jack the tube up slightly to relieve the pressure in the roll back/dump cylinders. They are usually the culprit when it is hard to reattach the couplings, as the bucket will tend to roll back under it's own weight over time when stored, which in turn pressurizes the cylinders/lines. You can also just grab the torque tube and lift the bucket up by hand (the buckets/loader arms on the smaller units aren't so heavy that the average man can't lift them enough to relieve the pressure) a little and stuff some boards under it to hold it if you can't use a floor jack, or get one to where you're trying to hook back up at. Every JD FEL I have owned has had this same issue.
   / John Deere 1026 R #10
No I store it inside my pole barn at constant temperature. Yes, it sure would expand the hydraulic oil sitting outside in the sun! It would also contract if sitting out in the cold.
What your dealer showed you conflicts with the recommended install/removal in the loader manual. They specifically say to tip it up on the bucket lip. Well, you can't relieve hydraulic pressure from the tilt cylinders if you do that! Crazy.
Brock 60'x26' Flat Bottom Grain Storage Tank (A57148)
Brock 60'x26' Flat...
2005 Caterpillar 928G Articulated Wheel Loader (A55973)
2005 Caterpillar...
2018 Ford F-350 4x4 Ext. Cab Stellar FC3200 3,200lb 1.5 Ton Service Crane Truck (A55973)
2018 Ford F-350...
Year: 2017 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A56859)
Year: 2017 Make...
LOT: (8) Wheel Loader Bucket Teeth (A59076)
LOT: (8) Wheel...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
