John Deere 1026 Belt problems on deck
   / John Deere 1026 Belt problems on deck #1
denverdave66
Missouri
2012 John Deere 1016, FEL, 60"MMM
I don't know why my belt is flopping around so much it is wearing the paint off my deck. I noticed the spring that connects the idle pulley does not have any tension at all on it. Do I need a new idle pulley or what?
   / John Deere 1026 Belt problems on deck #2
Any pics to post to show what you have?
   / John Deere 1026 Belt problems on deck #3
Send us some pics of the deck. The belts do move around a little and wear paint off. But something could be wrong.
What the spring is attached to on the back
Where the idle pulley is if I move it towards the right it will put tension on it. T
C4A3FD8E-1DE4-44D4-8917-F79B7F43DB37.jpeg7C2572A9-5013-4197-95BE-5A28B80A2B21.jpeg2B1A83FD-1E0A-40D7-B873-AD70C6911780.jpeg
   / John Deere 1026 Belt problems on deck #6
That spring doesn’t look right. It’s suppose to be spread out more than that between coils. Doesn’t look tight at all
I know that痴 the problem. Don稚 know if there is a pin that suppose to be holding the back part down thats broke or just need to replace the idle puller system?
   / John Deere 1026 Belt problems on deck #8
Send a pic of the broken part your talking about.
This is the part the back of the spring is connected to. If I move that piece to the right it puts tension on the belt but then I let go no tension on belt b65973D82-F99B-48F2-8751-85E59D0701C6.png
   / John Deere 1026 Belt problems on deck #10
I can’t tell anything from these pictures. Can you take deck off and take a bird eye view picture of deck.
20X30 ALL STEEL CARPORT (A53843)
20X30 ALL STEEL...
Freightliner Tender Truck (A53473)
Freightliner...
2021 Simex TFC 400 rotary cutter, like  new (A52384)
2021 Simex TFC 400...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2010 John Deere 200 Crumbler Seedbed Finisher (A53117)
2010 John Deere...
