John Deere 1025R code problem.
/ John Deere 1025R code problem. #1
BobcatTR
Decatur, IL.
Bobcat CT225
I have a 1025R coding 523591.14
Says reverse and forward pedal wiring swapped.
Was driving thru yard, when this code popped up. How did my wiring get swapped???? Lol!
Now PTO comes on but when going forward or reverse it shuts down the PTO.
Anyone else, experience this problem?
Thanks very much for your help!
Terry
/ John Deere 1025R code problem. #2
I would start by looking to see if there are any disconnected, broken, or pinched wires for the F/R pedals.
John Deere came and picked her up.
Warranty work.
I let you know when I find out.
/ John Deere 1025R code problem. #5
Watch out. Get your sales person involved. Maintenance will still want to charge you for it. Went through this on my lemony 1025R that had several trips of the guy out here to fix various things.
Hope they get it worked out and that nothing else goes on it.
Ralph
Ralph
Thanks Ralph. I'll let you know!
I hope this doesn't happen.
Sorry to hear about yours.
It's a lot of money spent.
Top plate shifted, pinched a wire.
Working Great now.
Zebra five was right.
I just missed it.
Thanks for your help guys.
/ John Deere 1025R code problem. #8
Was using the FEL yesterday and looked down to see the yellow exclamation on my 2025R. It went away too fast, all I caught was the 5 and then the 14 on the next screen - some searching led me here, and I think it's the 523591.14 code. I've had it come on very intermittently over the past year, always when creeping backwards, which seems to match others' experiences.
I saw @dodge man post about this on a different forum many years ago - did the problem ever progress to where you had to fix something? I think I'm just going to do nothing until it becomes a problem that I can reproduce, and will look for wires when I do the driveline greasing in the spring.
It's funny, I've replaced a broken pedal, installed the auto-throttle, and done the idle forward/backwards creeper adjustment, and never noticed any switch or wires down there. Looking at the parts diagram, I'm not even certain if it's this or not:
30 -Sealed Plunger Switch​
Part Number
LVA13307
Also did some looking for how to recall trouble codes, everything references pushing a "roll mode" switch - seems like it's for larger tractors, even though the site specifically had instructions for the 1025R - I blame AI slop for that. Any way to check the codes at home?
/ John Deere 1025R code problem. #9
I still get the code on mine when backing up very slow. My tractors about 7 years old and no problems from it.
2021 John Deere 50G Mini Excavator $6000 Hydraulic tilt bucket (A62613)
2021 John Deere...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
2014 CATERPILLAR 573C FELLER BUNCHER (A64276)
2014 CATERPILLAR...
2016 Nissan Altima Sedan (A64557)
2016 Nissan Altima...
New/Unused 12V Diesel Pump with 50ft Hose (A65583)
New/Unused 12V...
