John Deere 1020 Tractor Stalls after two minutes
   / John Deere 1020 Tractor Stalls after two minutes #1
lanceb36
Port Orchard, WA
John Deere 1020
I have a John Deere 1020 that has been running well for a long time. My son borrowed it and put premium gas into the tank (all he had on hand) now the tractor starts great but only seems to run for about two minutes before sputtering as if it is running out of fuel. If I choke it or wait a bit (five to ten minutes) it will start beautifully and run again for about two minutes.
I have cleaned the carburetor, Oil Bath, and added lower octane fuel to no avail. It starts really well and runs great when it runs then it will run about two minutes and sputter and die.
any guidance would be appreciated.
Lance
   / John Deere 1020 Tractor Stalls after two minutes #2
Welcome to TBN..................
How long was his premium gas sitting before he poured it in.
Perhaps it got condensation (water) in the gas.
Try a bottle of dry gas.
   / John Deere 1020 Tractor Stalls after two minutes #3
Hopefully it is the gas engine and not the diesel. Which I presume it is.
The premium fuel may not be the problem, just that another cropped up at the same time.
Next time, try removing the fuel cap just when you think it is going to die... see if there is a venting problem.
Be sure there is good fuel flow out of the tank, as some debris may be plugging up the fuel line either in the line or in the tank.
:welcome: to TBN
Thank you, it was new gas (mine too :laughing:) but I will try that.
I will try that, thank you.
   / John Deere 1020 Tractor Stalls after two minutes #6
It may be time to replace the fuel filter too.
If it's been in a while it may be partially plugged causing the tractor to run out of fuel.
We are assuming that since you mentioned adding gas you have a gas engine and not the diesel.
thank you, I can confirm that I have a gas not diesel engine. I cannot find an inline fuel filter of any kind. I could certainly add one.
   / John Deere 1020 Tractor Stalls after two minutes #8
Did he put the gas cap back on rightly?
I had this happening to my old JD 14SB walkbehind. I'd gotta the cap gasket backwards. There's a hole in it that allows air into the tank. Backwards, the hole was being plugged up.
Ralph
   / John Deere 1020 Tractor Stalls after two minutes #9
Remove the fuel line from the inlet side of the transfer pump and direct the flow into a bucket,if the flow slows or stops after 1 or 2 minutes most likely the
shutoff fitting on the bottom of the tank is obstructed . The fitting can be removed from the bottom without removing the tank. Good luck!
   / John Deere 1020 Tractor Stalls after two minutes #10
There is a filter screen in the carburetor inlet fitting. Disconnect the line and remove the elbow from the carburetor. The screen is attached to the elbow
Wolverine Mini Skid Steer Grapple Bucket (A50514)
Wolverine Mini...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2013 International Day Cab Semi (A50120)
2013 International...
John Deere 960 Culitivator (A50514)
John Deere 960...
Land Honor Skid Steer Backhoe Arm Attachment (A50515)
Land Honor Skid...
2020 Case TR310B Skidloader (RIDE AND DRIVE) (A50774)
2020 Case TR310B...
